Has anyone got Samba 3 for MOS to work?
    Posts: 903 from 2003/3/4
    It doesn't work here at all. It leaves 2 smbd instances that can't be quit or break'd and that use 100% cpu every time something tries to connect to it. I can connect locally to non-passworded shares. But remote, and passworded accounts don't work, so it's not much use. The logs are full of weird stuff like...
    [2004/06/27 17:25:08, 0] smbd/sec_ctx.c:push_sec_ctx(264)
    Out of memory in push_sec_ctx()
    And nmbd can't be run using -D, so that's another problem.
    So has anyone really got this version of Samba to work at all? If so, were you using Miami/MiamiDX and how did you manage it?
  • »27.06.04 - 14:34
    Robin
    Posts: 741 from 2003/2/24
    First read the News again.
    There is an update to remove the 'weird' part.
    Second MiamiDX connected to a wlan-router
    connects fine to and from a winxp laptop.
    amitcp:Samba/lib/smb.conf
    [global]
    workgroup = MYGROUP
    netbios name = pegasos
    server string = Tester
    security = SHARE
    log file = /Samba/log/log.%m
    max log size = 500
    load printers = No
    local master = No
    guest account = pcguest
    guest only = Yes
    guest ok = Yes
    [All]
    comment = All volumes in the system
    path = /Test
    public = yes
    only guest = yes
    writable = yes
    printable = no
    map archive = no
    map hidden = no
    map system = no
  • »27.06.04 - 14:59
    I'm already using the update. All it does is removes debug stuff in the output for speed. It doesn't stop fatal debug output, which is needed. So that's not the problem.
    My conf file (although I've tried MANY others):
    [global]
    workgroup = HOUSE
    netbios name = PEGASOS
    server string = Pegasos / MOS
    encrypt passwords = Yes
    update encrypted = Yes
    map to guest = Bad User
    null passwords = Yes
    debug level = 0
    syslog = 0
    log file = /samba/log/log.%m
    max log size = 50
    debug timestamp = No
    dns proxy = No
    [MorphOS]
    comment = MorphOS System
    path = /sys/
    valid users = kennyr
    write list = kennyr
    [Storage]
    comment = Storage Archive
    path = /storage/
    writeable = Yes
    [All]
    path = /
    writeable = Yes
    It's not a conf file issue. All configuration files do the exact same.
    Robin, do a status in cli. How many smbd instances has it launched in your system? And are you using Miami?
  • »27.06.04 - 15:06
    Robin
    My full status using MiamiDX:
    Test:> status
    Process 1: Loaded as command: Samba:sbin/nmbd
    Process 2: Loaded as command: mossys:ambient/Ambient
    Process 3: Loaded as command:
    Process 4: Loaded as command: dnetc
    Process 5: Loaded as command: rx
    Process 6: Loaded as command: IRCd:ircd
    Process 7: Loaded as command: Samba:sbin/smbd
    Process 10: Loaded as command: smbfs '//PC/Ordner'
    Process 11: Loaded as command: RX
    Process 13: Loaded as command: status
    Have you perhaps tried Snoopdos ? Or removing the
    valid users for at least one share ?
  • »27.06.04 - 15:57
    Robin
    Played a little with your config.
    It does not connect until I remove the '/' from
    your server string ... hope this helps :-)
  • »27.06.04 - 16:08
    Process 10: Loaded as command: Samba:sbin/nmbd
    Process 11: Loaded as command: Samba:sbin/smbd
    Process 12: Loaded as command: Samba:sbin/smbd
    Process 13: Loaded as command: Samba:sbin/smbd
    Process 14: Loaded as command: Samba:sbin/smbd
    Process 15: Loaded as command: Samba:sbin/smbd
    Process 16: Loaded as command: Samba:sbin/smbd
    Process 17: Loaded as command: Samba:sbin/smbd
    Process 18: Loaded as command: Samba:sbin/smbd
    Process 19: Loaded as command: Samba:sbin/smbd
    Process 20: Loaded as command: Samba:sbin/smbd
    Process 21: Loaded as command: Samba:sbin/smbd
    Process 22: Loaded as command: Samba:sbin/smbd
    Process 23: Loaded as command: Samba:sbin/smbd
    Process 24: Loaded as command: Samba:sbin/smbd
    Process 25: Loaded as command: Samba:sbin/smbd
    Process 26: Loaded as command: Samba:sbin/smbd
    That's what I get, every time. And thats just a few connections. Seems smbd at least is still broken.
  • »27.06.04 - 17:35
    DJBase
    Posts: 745 from 2003/4/6
    A kingdom for more high quality ports.
  • »28.06.04 - 11:46
