Debian Help
    Posts: 81 from 2004/3/20
    I am running beta4 of Debian on my Peg II and did an apt-get update to
    the system a couple of days ago. Now, eth0 isn't found and I've lost
    all my x-windows systems except the failsafe gnome gui. Dunno what
    the heck happened but I'm in a mess.
    Guess first thing would be to be able to correct the eth0 problem. Is
    there a simple fix that anyone would know of to do this?
    Thanks.
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »29.05.04 - 08:31
    hiTCH-HiKER
    Posts: 169 from 2003/12/31
    I got eth0 back by using the PegII 2.6.4 kernel to boot the system...
  • »29.05.04 - 10:55
    Will give it a try, thanks. I had heard that creating an alias in a
    file somewhere would also recover it, but haven't had too many
    specifics on this. Was hoping someone had done this.
  • »29.05.04 - 13:16
    Which URL can I find the Peg II specific install iso? I know there is
    one as I had an email..(Now lost), that pointed me to it in the debian
    web maze. Can't find it now....the iso image that is.
    Thanks.
    Harry
  • »30.05.04 - 00:02
