MOS1.4.2 freezing when opening drawer with big icons!
    hiTCH-HiKER
    Posts: 172 from 2003/12/31
    I don't know if this bug is known, but I just created some 160x160
    pixel icons with ShowGirl0.5 and while showing those icons MorphOS
    often crashes.
    Here are the icons, just decrunch them to RAM:
    CLICK
    Then open the "icon_test"-directory in Ambient... best way to make it
    freeze fast is to resize the window while the icons still load... but
    even without doing so Ambient freezes after a while playing around
    with the icons!
    Anyone can confirm that?
  • »22.05.04 - 10:31
    tokai
    Posts: 1289 from 2003/2/25
    hmm... did not crashed here or something. worked nicely. Opened your test drawer a few times... no problems.
    but just make sure you don't have _too_ much files in one directory. :-)
    and i strongly suggest to use a template and make the thumbnails a bit smaller... that will look better then.
  • »22.05.04 - 10:37
    tokai
    oh.. and it goes to fast for me.. i cannot resize the window while loading the icons... as soon i reach the size gadget all icons are loaded already :-)
    Peg2/G4 here.
  • »22.05.04 - 10:39
    hooligan
    Posts: 1948 from 2003/2/23
    Works perfectly fine here.
    And yes, they load up too fast.. its impossible to try resizing window while they load.
  • »22.05.04 - 10:58
    hiTCH-HiKER
    try playing a bit around, maximize the window to your full desktop
    size, then sort the icons, move the drawer around etc., then it will
    freeze sooner or later... I could reproduce it every time and my
    MorphOS isn't messed up, so I doubt it only occurs here!
    I have a Peg2/G3...
  • »22.05.04 - 10:59
  • Leo
    Leo
    Posts: 428 from 2003/8/18
    Couldn't reproduce it... I resized the window to full desktop, used the sort command, moved icons, copied icons,... I also tried to play with icon size of Ambient prefs: no freeze.
    Peg1/G3.
    Btw, where can I find full size versions of these pics ? ;)
    Leo.
  • »22.05.04 - 12:46
    hiTCH-HiKER
    I just tried again twice and I always get a freeze... sometimes while I resize the window, sometimes a bit later... what could be the cause?
    I would appreciate if you try it 2-3 times, so we can see if this is a MorphOS issue or just something wrong on my system... btw. I use a Radeon 7500, could also be a graphics driver problem...
  • »22.05.04 - 13:05
    Posts: 1932 from 2003/10/19
    No problems here. I am using a Peg G4 with a Radeon 7000 card.
  • »22.05.04 - 15:26
    Paochi
    Posts: 136 from 2004/3/23
    it run perfectly here.
    it's better if you reinstall the OS or check the mcc class you installed-substiuted.
    "I hope that all my toys are, first of all, funny!" (Jay Miner)
  • »22.05.04 - 15:29
    hiTCH-HiKER
    it doesn't freeze every time, but most times... so if you all tried
    2-3 times and it worked, then its a problem here... but which files
    are involved in Ambient icon image decoding?
  • »22.05.04 - 18:24
    Robin
    Posts: 741 from 2003/2/24
  • »22.05.04 - 18:55
