Is there a way to use the page up/down keys in Voyager to scroll up/down?
As a workaround it may be possible to do that: I know that there is a MUI class capable of reading those keys, so is there maybe a tool that can convert page up/down key presses to Shift+Arrorw-Up/Down?
yes thats true in Voyager but APDF for example only supports "Shift+Up/Down". As there is a MUI class which can handle them, it should be no problem for MorphOS to map those keys to "Shift+Up/Down" (or give us the possibility to map them to whatever we want), which would be great in Voyager or APDF!
