Diapos - a new presentation software on MorphOS
    tomasz
    Posts: 25 from 2026/2/11
    You're amazing. The presentation software perfectly fills the gap in the office suite. I'm rooting for this project.
  • »25.03.26 - 15:58
    tomasz
    What level of PowerPoint compatibility would you ultimately like to achieve?
    1. None (only working in the MorphOS environment)
    2. Ability to export to .PPTx
    3. Ability to import from .PPTx
    4. Export and import to and from .PPTx?
    Regardless of the answer, I think the idea is great. I noticed the PDF icon, so exporting to .PPTx is also theoretically possible using online tools: https://pdfguru.com/app/pdf-to-pptx
    [ Edited by tomasz 25.03.2026 - 18:10 ]
  • »25.03.26 - 18:09
    r-tea
    Posts: 316 from 2005/3/27
    As for the name: Diapos. Sounds great for me.
  • »30.03.26 - 18:30
    Posts: 2077 from 2003/6/4
    Papiosaur schrieb:
    Hello,
    i present you Diapos (the small brother of Stylos) in alpha stage:
    Nothing against your effort, but we have quite good presentation software already: The Hollywood Designer.
    Quite powerful.
  • »30.03.26 - 18:58
    tomasz
    Quite powerful.
    Indeed, Designer is a great program. It has only two drawbacks: I can't open a presentation created in it in PowerPoint, and I can't open a presentation created in PowerPoint in it.
  • »31.03.26 - 14:42
    NewSense
    Posts: 1576 from 2012/11/9
    @ tomasz direct quote from Hollywood - Designer page:
    "The Hollywood Designer is currently only available for Amiga compatible systems. Executables for Windows, macOS, and Linux can be compiled just fine with the Amiga version of Hollywood Designer, though."
    So, a Designer script can be viewed on Windows, and other systems, once it has been compiled.  8-D
    Though obviously not directly in PowerPoint or Keynote, etc..  :-( Well not as yet!  ;-)
    I only mention it, just in case you weren't aware of this option of viewing Designer files on other OS's.
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »02.04.26 - 04:29
    tomasz
    This thread isn't about Designer, so there's no point in speculating about its pros and cons. Papiosaur presented his proposal, and I may have scared him a bit by asking about PowerPoint compatibility. It would actually be nice to have at least a simple presentation program that could be saved in the RTF format, which probably isn't difficult, since it's already available in its "big brother," Stylos. RTF can be converted to PPTX using online tools.
  • »02.04.26 - 17:53
    Papiosaur
    Posts: 2524 from 2003/4/10
    Zylesea a écrit :
    Papiosaur schrieb:
    Hello,
    Quite powerful.
    Diapos does not intend to be a competitor of Designer who is a very powerfull presentation software with many options. Diapos will be more simple, the goal here is too have some import/export compatiblities with external formats.
  • »02.04.26 - 19:14
