PhotoPrint
    tomasz
    Posts: 67 from 2026/2/11
    I missed MorphOS's ability to easily print photos to an inkjet printer. I was told the solution was to "wrap" the photo in PDF format and print it using VPDF. However, it was still quite tedious to prepare the photo in the correct format so that the printer would show exactly what was on the screen.
    Ultimately, I decided to try to create something similar in Hollywood, and I'd like to share the results of my efforts. Perhaps someone will find it useful for printing photos on MorphOS. This tool allows you to crop a selected fragment from a source image in a selected format (9x13, 10x15, 13x18, A4), save it to a temporary directory as a PDF, and automatically launch the VPDF program, which prints the photo on a printer. For best results, select the same paper size in your printer settings as the cropped photo  ;-).
    Here's the link: amiga.icu/dwnld.php?lng=en&delay=8&pg=2
    [ Edited by tomasz 15.03.2026 - 07:21 ]
  • »15.03.26 - 07:21
    Tomtom76
    Posts: 49 from 2021/6/26
    Thank you. Great idea.
    Powerbook G4 A1106 MorphOS 3.20 & MacOSX 10.4
  • »15.03.26 - 08:27
