    Posts: 3275 from 2003/3/5
    Youtube made some updates recently it seems. I'll be releasing 10.6 soon.
  • »28.10.25 - 20:25
    Posts: 465 from 2019/5/9
    @jacadcaps:
    Thanks!
  • »29.10.25 - 04:20
    Primax
    Posts: 204 from 2021/7/2
    It's actually great that I can visit almost every website out there with Wayfarer. Superb.
    But unfortunately, it's also frustrating how often you get slowed down while surfing and have to wait forever...
    I appreciate all the time and work invested in this great project. If I had a wish: please check if there are any options to accelerate the browsing.
    Maybe a query asking whether I want to load all content. And which content.
    It's great when I can visit all the websites, but somehow also quite useless when it takes so long.
  • »01.11.25 - 13:53
    matt3
    Posts: 772 from 2004/2/10
    Currently MorphOS is very CPU hungry using Wayfarer, your best experience would be to pick up a PowerMac PCIX @2.7GHz or a PCIe@2.5 GHz, the raw power of the CPU and the Altivec capability drive MorphOS as fast as it can go currently.
    I see those system under $200 and even $100, so it will be a cheap system. I recommend using 2 displays if you want to use it for productivity. There are some videos out there on the YT by Chris Edwards and others that can give you an idea of browsing performance on those systems.
    YMMV, but I'm on wayfarer all day on my 2.5 PCIe PM and for most of my browsing is a nice experience for very intensive sites it will a burden.
    Good luck!
    [ Edited by matt3 02.11.2025 - 08:05 ]
  • »02.11.25 - 12:41
    Wayfarer 10.6 is now available for download. This version updates WebKit to WebKitGTK 2.48.6 and addresses several major issues.
    CSS Gradients are now fixed to render correctly. Settings defaults are now always correctly updated to include latest Youtube presets.
    Additionally, the simplified Youtube interface moved from now defunct youtube-nocookie.com onto a self-hosted solution. The first time you navigate to youtube.com or m.youtube.com, you will be asked which interface to pick for video playback. Choose Simple mode to enjoy fast load times on a bare-bones youtube player.
  • »12.11.25 - 19:11
    analogkid
    Posts: 713 from 2004/11/3
    Thanks jaca!
  • »12.11.25 - 19:33
    Tomtom76
    Posts: 40 from 2021/6/26
    Thank you Jaca. Great job!!!
    Powerbook G4 A1106 MorphOS 3.19 & MacOSX 10.4
  • »12.11.25 - 20:43
    Posts: 916 from 2004/1/24
    Well you made my day :-)
  • »12.11.25 - 21:17
    The CSS bug took a lot of time and effort to find - I was close to giving up tbh. Ended up breaking and retiring my hackintosh after trying to update it to latest macOS, replacing it with a M4 mini all so that I could step through the code in XCode. Luckily, it seems that this was also the main blocker I've found with Wayfarer 11 (WebKitGTK 2.50.0), so I can resume the work on that port now.
  • »13.11.25 - 13:04
    Chefsessel
    Posts: 15 from 2018/1/5
    Thank you very much for the update, jacadcaps! Working fine on my little guy (1.25 Ghz Mac Mini G4), updating went without a hitch. Awesome effort! (I believe we say that too rarely, so I had to post this there :) )
  • »15.11.25 - 12:41
    Wayfarer 11 is now out!
  • »20.11.25 - 12:10
    matt3
    Thank you Jaca!
  • »20.11.25 - 14:31
    Posts: 47 from 2020/10/11
    Thanks Jaca !!
  • »20.11.25 - 14:50
    Tomtom76
    Updated. Thanks Jaca
  • »20.11.25 - 14:54
    Primax
    Thank you!
    Just one thing stays the same: after I have logged out here, it is written:
    "Danke für Ihren Besuch...."
    Only the "ü" doesn't seems to work. Can the other German guys here confirm that?
    [ Editiert durch Primax 20.11.2025 - 18:21 ]
  • »20.11.25 - 17:19
    W00t :-D
  • »20.11.25 - 18:17
    analogkid
    Jaca, your are a living coding machine.
    Thanks!
  • »20.11.25 - 19:06
    Posts: 591 from 2003/4/11
    Primax schrieb:
    Thank you!
    Yea, confirmed. This is pretty much the same on any other "mainstream" browser like Edge, Firefox or Chrome and not directly related to Wayfarer.
    At least the german strings seem to be encoded in UTF8 but displayed in ISO-8859(-1), so any characters which are not part of the legacy US-ASCII character set are affected (like ä,ö,ü,ß and lots of others). If that is some limitation of the forum software and/or its encoding of HTML pages, I don't know ...
  • »21.11.25 - 02:14
    Primax
    cyfm schrieb:
    Primax schrieb:
    Thank you!
    It's really confusing....
    Because if you log in here, it is confirmed in English (Thanks for logging in or something like that).
    But if you log out, then it is confirmed in German...
    And secondly: it is not possible to encode the "ü" correctly, but it does ciprectly for the "ä":
    "Falls die Seite nicht automatisch neu lädt, klicken Sie bitte hier...".
  • »22.11.25 - 05:20
    Primax
    PS: and super cool: it is correctly written "Danke für ihren Beitrag"!!! :))
  • »22.11.25 - 05:21
    Wayfarer 11.1 is now out!
    - Rebased to WebKitGTK 2.50.4
    - Fixed fullscreen mode immediately switching back to windowed
    - Disabled SVG radial gradients to improve performance
  • »24.01.26 - 12:35
    Much yay, thanks jaca!
  • »24.01.26 - 19:34
    analogkid
    Thanks jaca!
  • »25.01.26 - 03:09
    Primax
    @Jacek
    As soon as a video has started playing - regardless, if it is a YouTube video or a video embedded in a website: is there any chance to get access to the quality playback option of the video (several SD, HD etc.) and put that in the Wayfarer menu just like fullscreen?
    Because it is always a hussle to access any video option within the video. It does not work very well.
    (@admins: if I go with Forum Index » User Forums » Applications, then 76 sites are listed for "New Modern Webkit-based Browser In Development" topic. Odd, because right now it only has 75...)
  • »10.02.26 - 03:25
