PSA (Superbundle)
    Bifford
    Posts: 283 from 2003/2/24
    Hi folks
    I know there are people out there using PSA on MOS1.4.2 but how have you managed it?
    When I click the icon it brings up the screenmode requestor (all 8bit modes). All of the modes work initially, but about 3 seconds after the PSA screen and windows pop up it automatically shuts straight back down again! There's nothing I can do to stop it.
    Anyone...?
    TTFN!
    Bifford
    Bifford the Youngest
  • »01.05.04 - 10:59
    Posts: 2565 from 2003/2/24
    tried snoopdos?
  • »01.05.04 - 11:18
    Elektro
    Posts: 202 from 2004/2/3
    @Bifford
    Hallo,
    I've tryed the DEMO version..is the same....it runs and auto-shutdown ..come back to MOS Desktop...
  • »01.05.04 - 15:03
    hellbeard
    Posts: 15 from 2004/5/1
    Do you have any 8bit modes in your System settings > mode edit?
    If not try adding a couple.
  • »01.05.04 - 20:09
    Bifford
    tried snoopdos?
    yup. fails on Audio.device (also looks for Audio.device.elf)
  • »02.05.04 - 17:32
    Elektro
    You should try to change the File AHIinOut.
    You can find the file here.
    http://www.audiolabs.it/files/index.html
  • »02.05.04 - 18:36
    Bifford
    Hi Elektro,
    That file was already in PSA/Drivers/ but I downloaded the verison on the net and replaced it. Same version but the newer file was Earlier in date.
    It makes no difference. PSA still starts then quits.
    Bifford
  • »02.05.04 - 19:01
    Elektro
    >by Bifford on 2004/5/2 23:01:17
    Hi Elektro,
    Bifford
    Perhaps we have to wait for a new version of AHI (Is really bugdeg this one...)
    I've tryed a some Music Software but no-one works...AmySequencer,HD-Rec,AudioEvolution68k and the new DigiBooster and also SamplitudeOPUS...
    Everytime that I load samples files the software crashdown!  :-(
  • »02.05.04 - 19:38
    Bifford
    hmm, well the only one i really use is SoundProbe. This works but is somewhat "odd" under MOS. The graphs refuse to draw, and the waveforms themselves take forever to "compute" but then draw in a fraction of a second. Other than that it appears to work ok though I havnt tried it for recording only manipulation.
    Still remains that other people have PSA working fine but I cant get it to for some reason.
    As to 8bit screens (one of the other poster's comments) I have about 8 in my list and each of them successfully displays PSA but PSA still quits some seconds after startup. Its not screenmodes at fault.
    TTFN!
    Bifford
  • »02.05.04 - 19:47
    Jupp3
    Posts: 1193 from 2003/2/24
    "I didn't do anything! It just works!"
    And I'd say I have quite "typical" morphos installation, can't see why it wouldn't work on your Pegasos...
  • »03.05.04 - 07:14
    Posts: 918 from 2004/1/24
    A little bit offtopic maybe, but in reply to Elektro: Quote:
    Perhaps we have to wait for a new version of AHI (Is really bugdeg this one...) I've tryed a some Music Software but no-one works...AmySequencer,HD-Rec,AudioEvolution68k and the new DigiBooster and also SamplitudeOPUS...Everytime that I load samples files the software crashdown!
    You could try SampleZ, which is a wonderfull freeware sample-editor that works without any probs under MorphOS. It's a bit basic, but does support MP3 input and is great for basic sample-editing :-)
  • »03.05.04 - 07:34
    hiTCH-HiKER
    Posts: 172 from 2003/12/31
    I use SampleManager, which works great
    on MOS and is still supported by the developer.
  • »03.05.04 - 07:54
