The becoming of TurboPrint
    Brumiga
    Posts: 274 from 2004/4/3
    I have an important question certainly about printing subject. Are there still people using TurboPrint to print anything ? Should TurboPrint be kept with MorphOS ? Is it possible to remove TurboPrint from MorphOS after disabling the assignations related to it ? Should the MorphOS Team remove TurboPrint from the ISO image of the upcoming 3.20 version and beyond ?
    Brumiga
  • »30.09.25 - 12:11
    Posts: 477 from 2019/5/9
    @Brumiga:
    And what is the reason for removing Turboprint? I don't use it, but it doesn't bother me in any way. Has anything changed in the last two years since your last survey?
  • »30.09.25 - 16:17
    Brumiga
    I did not remenber the other thread opened for the same subject.
    Administrators, please could you close this thread or better delete it, simply. Thanks.
    Brumiga
  • »01.10.25 - 06:02
