Flowchart Software
    Posts: 13 from 2025/9/2
    Are there an recommended applications specifically designed to make flowcharts for Morphos?
  • »22.09.25 - 17:53
    Papiosaur
    Posts: 2591 from 2003/4/10
    i don't think, do you have an example of software doing that?
    Maybe a software to port from Github or create one from 0 maybe?
  • »23.09.25 - 10:55
    Well, I've been using Umbrello in the past on my Linux machine which admittedly is far more complex than I personally need. But I've found it invaluable in planning some projects.
    Calligra Flow is another, but I believe it's been abandoned.
    Regrettedly I lack the skill to port software or write such engineering wonders from scratch. My stuff is simple (yet I still need flowcharts- lol).
  • »23.09.25 - 11:32
    Nadir
    Posts: 178 from 2003/3/17
    Writing such an application is much easier with a good vector graphics engine in place. Fortunately we now have ThorVG (https://www.thorvg.org/) in beta as a shared library so I think this would definitely be feasible for someone interested to take up that job.
    A more complete vector graphics application would also be cool. I don't think I have the time for this myself though.
  • »24.09.25 - 04:59
    Then I guess a vector graphics application would have more interest and thus a higher priority. It would be very usable, the only thing I'd personally miss is a small pop-up note explaining in more detail what each element on the chart does when it's clicked. Maybe that can be done through some kind scripting anyway?
  • »24.09.25 - 09:24
    Magicalink doesn't seem usable at all.
    Pagestream sparks my interest, and is something I'd like to support sometime. But seems very complex and with a lot of windows to manage, and too expensive for me at the moment.
    It's very kind of you to volunteer to start a project like this, but it might be good to gauge the overall interest in the community before committing to such a task. I'm sure there's a bunch of other things far more important to get done.
    Not trying to be rude or anything, just making sure your time and energy is well spent.
  • »24.09.25 - 12:32
    analogkid
    Posts: 720 from 2004/11/3
    Maybe the Hollywood Designer could offer what you need?
    https://hollywood-mal.com/designer.html
    It's commercial, but every cent worth.
    Or RNOPublisher, a freeware DTP application made with Hollywood.
    https://jpv.amigaaa.com/RNOPublisher/
    [ Edited by analogkid 24.09.2025 - 14:37 ]
  • »24.09.25 - 13:35
    Papiosaur wrote:
    @ollie: i could start simple and add new features progressively in functions of needs of the communauty.
    Sure. Then by all means- work your magic. :)
    Thanks for all the software suggestions, guys. Appreciate it. :)
  • »24.09.25 - 15:41
