Easy2Install
    Papiosaur
    Posts: 2510 from 2003/4/10
    DJBase a écrit :
    Yes, Origo is the default theme in MorphOS. If I change Global MUI settings to Ater it will freeze the system.
    Oh ok!
    Bizarre this freeze, i will test that, thanks
    Beta 38 available on MorphOS-Storage :-)
  • »05.10.23 - 17:05
    cip060
    Posts: 148 from 2010/7/30
    Unfortunately in the games section the line jump has reappeared in the list
  • »06.10.23 - 09:42
    Papiosaur
    Thanks for your return, like before i need to know the game cause trouble please because there are many, many games... a lot of games are already supported but not all for the moment.
    What is the section please? Action, adventure, etc.
    Thanks for your return to help me.
    [EDIT]
    I have fixed:
    - RawGL
    for next beta.
  • »06.10.23 - 09:52
    cip060
    any news
  • »13.10.23 - 08:19
    Papiosaur
    cip060 a écrit :
    any news
    "What is the section please? Action, adventure, etc."
    @cip060 as already said, i need archives name make troubles...
    It's impossible for me to test all archives, i need help for that...
    I wait your answer to improve the support of archives make troubles.
    You can answer on this specific thread
    Thanks
  • »13.10.23 - 09:00
    cip060
    I was looking forward to a new beta thanks
  • »20.10.23 - 15:28
    Posts: 47 from 2020/10/11
    Papiosaur wrote:
    beta 39 available
    - added new banners (Wayfarer and Iris)
    - new archives fixed as stated in the IMPORTANT NOTE in ReadMeFirst.txt file
    - added more MUI Bubbles info
    - improved english texts (thanks NewSense)
    Thanks so much for your fantastic piece of software!
  • »20.10.23 - 16:18
    Papiosaur
    @Skateman: Thanks! I'm not alone in this project (see About window and ReadmeFirst)
    @ALL: Don't hesitate to return me if some archives are not supported (see ReadmeFirst for explanations), i will work on them for next release :-)
    Specific thread
  • »20.10.23 - 17:26
    cip060
    Then tried with all sections
    network and game shoot 3D I feel like messing up the list
    I've tried all of them and only these 2 are bothering me. The alignment of the files skips a line for each file
  • »21.10.23 - 15:23
    cip060
    UP
  • »26.10.23 - 15:27
    Papiosaur
    Hello cip060,
    you have already mentioned this trouble and i have already answered : "I NEED THE NAME OF ARCHIVE(S) CAUSE THIS TROUBLE".
    If i don't have this info, you will have to wait until I have tested all the archives...
    It's always a beta version for many sort of problems like this (thanks to read Readmefirst)
    Thanks to reread my precedent posts too.
    If i didn't have returns from users maybe Easy2Install will stay a long time in beta version for problems mentioned... each archive has a particularity...
    I hope you could help me to resolve your problems.
  • »27.10.23 - 05:43
    cip060
    archive name is this
    network and
    3D game shoot
  • »27.10.23 - 07:12
    cip060
    When I enter these sections it loads the list skipping the lines
  • »27.10.23 - 07:12
    Papiosaur
    Hello,
    Easy2Install beta 50 available:
    - fixed: some duplicated dates in the database
    - fixed: sort column dates prior to loading a new database
    - deleted installation drawer from RAM: if rescan is clicked on after an installation via an installer script
    - added open drawer command after extraction of archives with installer script
    - now after clicking on the "download archive" button or when you install an archive without executable, the destination drawer is opened in list mode to view the archive
    - added a new button to enable reporting a problem with any archives
    - use extended option of AREXX WRITE command from Iris (Thanks to Jacadcaps for this new feature), add string "WRITE %a %s %b" like OpenURL_Prefs.jpg picture to your OpenURL prefs in MorphOS Settings.
    Easy2Install 1.0 beta 50
    Thanks for your suggestions, tests and don't hesitate to report problems with archives if necessary.
  • »08.03.24 - 12:04
    Papiosaur
    Hello,
    beta 51 is available on morphos-storage.
    for information i have added a button to report if you have problems with some archives.
    Strangely, i don't have receive any mail :-)
    ps: beta 52 is soon available with german language, thanks to Jay Konrad for the translation!
  • »18.04.24 - 06:36
    Papiosaur
    Hello everyone,
    a new beta is approaching, don't hesitate to send your comments, bugs or suggestions ;-)
    Here is the list of next features/improvements:
    - reset the progress bar to 0 after reaching 100%
    - opening decompressed archives without executable in lister mode (with the open directory button)
    - added a “Launch application” button
    - fix for opening the directory for OpenSSL which did not work (thanks BeWorld)
  • »26.05.24 - 15:05
    Papiosaur
    Hello,
    i rework on Easy2Install.
    Don't hesitate to do suggestions for next release.
    Actual changes for next release:
    - added: an option to iconify Easy2Install after an installation (maybe for a download too) (not saved in prefs i think)
    - added: activation of the lister at startup to select an entry with arrow keys (thanks jPV for the tip)
    - fixed: version string for Stratagus entry
  • »08.05.25 - 08:01
