How change the wallpaper automatic?
    Templario
    Posts: 558 from 2012/4/28
    I want cahnge the wallpaper but in Ambient settings but I can't activate the tab "activate effects" to do it, perhaps this problem will be resolve changinf some config file manually?
    Thank you for the help.
  • »12.06.25 - 06:57
    Posts: 3326 from 2003/3/5
    Pick a directory instead of a wallpaper and Ambient will automatically switch between images found in the directory.
  • »12.06.25 - 10:17
    Templario
    Thank you for your answer, it works, I didn't that it was so easy, the problem to work with several OS, every works of different way but with MorphOS is more easy, again thank you.
  • »13.06.25 - 07:31
