ProTrekkr
    hitchhikr
    Posts: 6 from 2025/3/27
    Bonjour,
    New MorphOS user here (very satisfied).
    I'd like to announce that ProTrekkr is now officially maintained and available for this OS.
    More information.
    Direct download link.
    Maybe it could be of some interest to someone around here.
    Have a nice day,
    f.
    [ Edited by hitchhikr 09.05.2025 - 18:04 ]
  • »07.05.25 - 14:47
    Britelite
    Posts: 68 from 2003/6/4
    Now this is some good news! :)
  • »08.05.25 - 06:43
    SkulleateR
    Posts: 72 from 2023/9/19
    Nice ! Have to try this one out for sure :-)
  • »08.05.25 - 09:03
    igracki
    Posts: 462 from 2003/2/24
    Could you please fix the protection bits of the files in the archive?
    All the files have the protection bits set to "SPARWED" or "SP-RW-D".
  • »08.05.25 - 10:50
    Posts: 2173 from 2003/2/24
    Yeah, I had to clear protection bits to get the program launched, but then it started fine. And would be nice to have files in a subdir in the archive.
    But what an entrance, welcome!
  • »08.05.25 - 11:38
  • MDW
    MDW
    Posts: 484 from 2003/7/25
    Great that the MorphOS port is now official. Ports of many programs for MorphOS/AmigaOS are often unofficial, and there's usually no information on the official project websites that such versions even exist.
    Thank you!
  • »08.05.25 - 11:43
    hitchhikr
    Thanks & sorry for the mess, here it is the first version of PRE 3 in lha format. That should fix the issue, right ?
    f.
  • »08.05.25 - 12:30
    beworld
    Posts: 664 from 2010/2/10
    Greats !!
    I delete my version on storage (if you want) ?
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »08.05.25 - 13:21
    hitchhikr
    As you wish.
  • »08.05.25 - 16:42
    matt3
    Posts: 748 from 2004/2/10
    Thank you for the software!
  • »08.05.25 - 19:47
    MoerBoer
    Posts: 237 from 2019/10/15
    Great stuff, thank you so much!
  • »09.05.25 - 04:12
    igracki
    I really like your ProTrekkr!
    Also like the modules! Nice!
    Is there a small standalone player for ProTrekkr modules?
    I created a Filetype definition for Ambient, so I can play them in ProTrekkr, but a small standalone player would be nice!
    btw, is there a keyboard shortcut to play/pause a module?
    I only find RETURN/ENTER to play while its pressed.
  • »09.05.25 - 10:37
    igracki
    The pre3 archive includes your ptk.cfg which has reference to a work: assign.
    [ Edited by igracki 09.05.2025 - 15:05 ]
  • »09.05.25 - 10:57
    hitchhikr
    There's a WinAMP plugin for the Windows version but nothing else, is there a plugins capable audio player for MorphOS ?
    All shortcuts are mentioned in the included PDF manual (playing a song is Right Control key).
    f.
  • »09.05.25 - 11:00
    igracki
    The best would be a reggae "datatype", then
    MorphOS only has support for one Ctrl key.
    Pressing Right or Left Ctrl key does nothing here!?
  • »09.05.25 - 11:11
    hitchhikr
    I'll what i can do about that.
  • »09.05.25 - 11:42
    hitchhikr
    PRE 4 released (with a couple of new shortcuts for MorphOS).
    f.
  • »09.05.25 - 14:04
