WormHole - Easy File Transfer MorphOS Windows AROS AmigaOS Android Linux + Other
    Posts: 70 from 2023/12/1
    WormHole for MorphOS...
    ... What Is It?
    an EASY way to transfer files on your local network between MANY platforms such as MorphOS, AmigaOS, AROS, Windows, MacOS, Android, Linux, just to name a few.
    Come see this beta version in action.
    TJ
    https://youtu.be/S1p9B0oPYq8
  • »26.03.25 - 16:43
    Posts: 3183 from 2003/3/5
    Wormhole works just fine in Wayfarer as well, btw.
  • »26.03.25 - 17:47
    I am not familiar with that at all.
    I thought Wayfarer was just a web browser.
    Are you saying there is a way to use Wayfarer on MorphOS and it see some portal on many different computers (Mac OS, Android, Linux, AmigaOS, etc...) and it transfer files with them?
    Point me in that direction if that is the case.
    Thanks
    TJ
    [ Edited by amigasociety 26.03.2025 - 09:37 ]
  • »26.03.25 - 18:21
    Ah gotcha, thanks.
    TJ
    Papiosaur wrote:
    @amigasociety:
    i think jacadcaps speak about the website with the same name.
    https://wormhole.app/
  • »26.03.25 - 20:18
    Alexco
    Posts: 33 from 2015/5/16
    Maybe you should simply watch the video and use this link for the software:
    https://software.kezdobetu.hu/wormhole.php
    (no, I did not test it)
    [ Edited by Alexco 27.03.2025 - 10:06 ]
  • »27.03.25 - 10:06
    Primax
    Posts: 179 from 2021/7/2
    Yes, but the charming thing about this application is that it is available for all Amiga systems in addition to Windows, so you can share data between OS3 and MorphOS or OS4 and Windows. Theoretically.
    I couldn't get it to work on my MorphOS-Windows test environment, I suspect the FritzBox is to blame...?!
    AmigaOne X5000 @ 2GHz / 4GB RAM / Radeon X1650 / AmigaOS 4.1 Final Edition / MorphOS 3.17
  • »27.03.25 - 10:16
    Yes, and is very cool it supports many platforms too.
    From Windows to Mac OS to Aros to MorphOS to AmigaOS to Linux, even Android and Amiga OS 3!
    It appears to be in beta grade to me but looks promising and I was able to get to work for smaller files well on MorphOS and my Mac OS system.
    It is these sorts of programs that lets me link to my main computers at the home office that may allow me to use and explore MorphOS more so I welcome them.
    TJ
  • »27.03.25 - 14:52
    MorphOS' built-in Networks will do a much better job for the purpose of local file sharing to/from anything that runs Samba/Windows file sharing.
  • »27.03.25 - 18:00
    Primax
    @amigasociety
    Have you tested it with LAN or WLAN? So, with or without cable?
  • »28.03.25 - 12:15
    tolkien
    Posts: 541 from 2013/5/29
    I tested It with an a1200 with wifi and a powermac g5 a with ethernet.
    It worked really good.
  • »28.03.25 - 13:37
    My X5K is wired to my router as I don't have wireless on that computer.
    Most of the rest of the house including my Mac Pro 2019 you see in my video is connected to the router wirelessly.
    So 1/2 and 1/2. haha
    TJ
    Primax wrote:
    @amigasociety
  • »28.03.25 - 15:57
    Primax
    My X5000 is also wired, but to a repeater. Everything else works wirelessly.
    So, basically it is cool if I do not have to set up a tool, but if it doesn't work, then it is bad...
    I also checked the settings in Windows: the app is allowed to communicate...
    TJ
    Primax wrote:
    @amigasociety
  • »29.03.25 - 05:52
    Does both computers show up inside the WormHole icon or just itself?
    Maybe try wiring a computer to the same router to see if that changes things. Maybe some oddball wireless issue?
    I know on my home network the router has 2.4 and 5ghz and if my printer connected to the 5 and a computer on the 2.4, I can't print.
    Maybe something similar?
    But wiring quickly both may be helpful.
    TJ
    TJ
    Primax wrote:
    @amigasociety
  • »29.03.25 - 18:02
