Problem with YT 2.7 and SmartClipBoard.sbar 1.4
    Papiosaur
    Posts: 2615 from 2003/4/10
    Hello,
    i'm configuring last YT 2.7 and try to use it with SmartClipBoard 1.4 in the next Chrysalis pack
    When i copy the YouTube link, i have the requester to do the action for YouTube links but after i have this error message:
    Command returned 5/1: <This space intentionnaly left blank!>
    A problem with a text file with a bad format after save?
    Thanks for your help!
    Thanks to Thomas Igracki for the adaptation of YT 2.7 from OS4 and SmartClipBoard!
  • »06.08.24 - 13:47
    Papiosaur
    ok, there is a problem...
    in the documentation of YT i must add
    assign rexx: sys:rexx/ in s:user-startup
    but there is a
    assign rexx: s: DEFER in mossys:s/startup-sequence
    if i put a ";" before the assign rexx: s: DEFER from mossys:s/startup-sequence it work.
    What i must do please? :-D
    i copy all rexx/ files from YT archive to S: and remove the new assign?
    [EDIT] Seems YT.rexx need a c:FileInfo not present in YT archive.
    [EDIT2] When playing video in streaming with MPlayer during download i have no sound, normal?
  • »06.08.24 - 15:12
