PegXMacSP_1.4.1 how to use ?!
    amif1team
    Posts: 16 from 2007/6/30
    Help me please to configurate PegXMacSP 1.4.1 - step by step... I have MacOS X 10.2. In help write that - this version of MacOS can work on my Pegasos 1. Please help me...
    -=\ amif1team /=- team Dogma
    http://www.dogma.org.ru
    http://www.amiga.org.ru
  • »13.07.08 - 16:11
    magnetic
    Posts: 2129 from 2003/3/1
    Hi
    You are much better running Molk. Just google Molk morphos..
  • »13.07.08 - 16:25
    Cego
    Posts: 738 from 2006/5/27
    molk doesnt work on Peg1.
  • »13.07.08 - 16:27
    keropi
    Posts: 131 from 2006/11/11
    where to get molk? I cannot find it...
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »14.07.08 - 04:06
    amif1team
    Yes ! I`m started MacOSX 10.2 - on my Pegasos 1 (by PegXMac SP 1.4.4) !
    [ Edited by amif1team on 2008/7/16 19:15 ]
  • »16.07.08 - 15:14
    Posts: 478 from 2019/5/9
    Hi, I used this old topics.
    Please, do somebody have PegXMac 1.4.1 for AmigaOne XE? ( PegXMacSPA )
    All links what I found is expired...
    I have now 1.4 GHz on my XE and want to test MacOSX here.
  • »19.04.23 - 14:38
    Flash
    Posts: 112 from 2019/11/1
    What is PegXMac? What is Molk? Never listen any of two.
  • »19.04.23 - 19:25
    Posts: 12552 from 2003/5/22
    > What is PegXMac?
    Linux live distribution for Pegasos and Eyetech AmigaOne that directly starts MacOnLinux.
    > What is Molk?
    Similar to above, but just for Pegasos.
  • »19.04.23 - 21:11
    Both of them is MacOS X running on top of linux system.
    Molk is better: easier configuration and lightweight mini linux. Exists for Pegasos 2, but not AmigaOne XE
    PegXMax: ubuntu with MOL ( mac on linux ), there were versions for AmigaOne XE (PegXMacSPA 1.4.1), Pegasos 1 ( PegXMacSP 1.4.x ) and Pegasos 2 ( PegXMac 2.0 ).
  • »20.04.23 - 05:11
    Posts: 846 from 2007/10/23
    In the past I compiled MOL myself, you don't need a ready distribution.
    [ Editiert durch polluks 22.04.2023 - 13:00 ]
  • »22.04.23 - 08:59
    @polluks
    I know, but I am not sure if I want to install old linux distro on AmigaOne XE and complie MOL after that.
    Much less work is install all via live CD.
    But if I will not find this, it is only possibility.
  • »22.04.23 - 13:49
    Indeed, http://pegxmac.zftp.com/amione.html is gone.
  • »24.04.23 - 12:07
    @polluks
    thanks, I found this. This is the exact version I need. But link to .iso gives error:
    "This server could not verify that you are authorized to access the document requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesn't understand how to supply the credentials required."
    I also wrote to the old emails. But... It is from 2006 ;-)
  • »24.04.23 - 14:34
