Extract audio from a VOB file
    Piru
    Posts: 624 from 2003/2/24
    ffmpeg should do the trick.
  • »29.03.23 - 13:23
    Posts: 1390 from 2010/1/6
    Mencoder does it from allmost every video-format:
    mencoder file.video -ovc raw -of rawaudio -oac mp3lame -lameopts cbr:br=128 -o RAM:file.mp3
    [ Editiert durch Amigaharry2 29.03.2023 - 18:23 ]
  • »29.03.23 - 14:23
    Papiosaur
    Posts: 2623 from 2003/4/10
    Thanks Amigaharry2 too! i will compare results ;-)
  • »29.03.23 - 15:49
    ThorstenS
    Posts: 80 from 2014/1/20
    A very good guide, !! here !!
    [ Editiert durch ThorstenS 29.03.2023 - 20:17 ]
  • »29.03.23 - 16:14
    Should'nt be a big difference - MPlayer/Mencoder based on ffmpeg-engine (afaik)....
  • »29.03.23 - 16:36
