uae4all2
    amiga4001
    Posts: 454 from 2006/11/16
    Not sure this is the right place for this.
    I installed uae4all2 on a mediapad t5 with android 8.0
    I want to get a hdf file or a bootdir to get a proper whdload system,to play them old nice games like turrican,apydia etc..
    There is no way I can get a hdf file created from euae (mint linux)to work,it shows up but formatting results in a non dos disk in the end.
    If I use a hdf file from the internet and start copying files nothing being copied.
    Same goes for a bootdir.
    Anyone know a workaround?
    Emulator runs ok for the rest,decent speed.
  • »10.02.23 - 19:12
    cip060
    Posts: 153 from 2010/7/30
    never had problems with hdfs if they work with winuae they also work with euae
    you do something wrong
  • »11.02.23 - 07:40
    cip060
    i use euae on my smartphone no problem when i copy files from pc to mobile and hdf files or the single folder with the amiga os inside workbench works without problems hdf and whdload of games and demos
  • »11.02.23 - 07:41
    amiga4001
    I checked on googleplay in the reviews,there is a comment about non working hdf with tablets.
    Guess I have bad luck.
  • »11.02.23 - 18:00
    Posts: 903 from 2003/3/4
    UAE4Droid supports HDF files, according to google play.
    Yes, UAE4Droid sucks. But pretty much every port of UAE sucks in one way or another, more or less, except WinUAE. Mostly people will be throwing ADFs at them, not trying to get their old Amiga software running on them, and they aren't all that well tested when it comes to networking/RTG/etc.
  • »11.02.23 - 21:52
