Crazy Mouse
    serge
    Posts: 725 from 2003/2/20
    hi
    I've just installed my debian for the first time succesfully.
    The only problem is with mouse.
    Mouse seems to be crazy.
    Could someone give the good parametres for the XF86Config-4 file ? please ?
    I have a PS2 mouse.
    Thanks
  • »18.07.03 - 06:01
    Senex
    Posts: 500 from 2003/2/17
    You are already on the right track!
    Try other mouse-options with "dpkg-reconfigure xserver-xfree86". For my wireless Logitech mouse I use "Explorer".
    To get into KDE without the crazy mouse, you could try to unplug the mouse during boot and then re-plug it in after the xserver started.
  • »18.07.03 - 17:17
    DethKnight
    Posts: 139 from 2003/6/24
    Section "InputDevice"
    Identifier "Mouse0"
    Driver "mouse"
    Option "Protocol" "IMPS/2"
    Option "Device" "/dev/psaux"
    Option "ZAxisMapping" "4 5"
    Option "Emulate3Buttons" "no"
    EndSection
    I am ; therefore you are
  • »18.07.03 - 18:33
    serge
    Thank you DethKnight  :-)
  • »18.07.03 - 18:40
    serge
    Thank you senex  ;-)
    It works now.
    I unpluged mouse and repluged it under KDE.
  • »18.07.03 - 18:57
    Granada
    Posts: 32 from 2003/12/30
    My mouse also does not work correctly in KDE, the pointer moves up an down when moving the mouse left and right.
    I am using a wireless optical Logitech keyboard/mouse connected via USB. I hope I can fix this with the hints given here (e.g. using explorer). My Mouse-Definition in XF86Config-4 also has a ZAxisMapping (was there by default), maybe that's the fault?
    Ruediger
    Mac Mini G4, 1.5GHz, MorphOS 2.7
  • »19.04.04 - 12:05
    Granada
    Ummm... nothing I tried works. :(
    The Keyboard works fine, but the mousepointer still only moves up an down when moving the mouse itself left and right.
    I have a Logitech cordless Mouse and Keyboard bundle, connected via USB.
    dmesg says:
    usb.c: registered new driver usbmouse
    usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
    usb.c: registered new driver usbkbd
    usbkbd.c: :USB HID Boot Protocol keyboard driver
    mice: PS/2 mouse device common for all mice
    What are the correct entries in /etx/X11/XF86Config-4?
    Kind regards
    Ruediger
  • »19.04.04 - 14:17
    DethKnight
    etx? not etc? wierd
    Identifier "Mouse0"
    Driver "mouse"
    Option "Device" "/dev/mouse" #(/dev/psaux for ps2 mice)
    EndSection
    normally works for my logitech cordless wheelmouse trackball
  • »19.04.04 - 19:56
