Graphic bugs in some games (SDL1?)
    Papiosaur
    Posts: 2613 from 2003/4/10
    Hello,
    i contact you because i have some graphics bug with some games (SDL1 ?) tested with MorphOS 3.17 tinyGL and last update TinyGL (16-12):
    - Tux Racer (menu)
    - SoulFu
    - Ri-Li
    - Fade2Black
    Any ideas ?
    Tested on G5 + Radeon 1950
    [ Edité par Papiosaur 19.12.2022 - 15:08 ]
  • »18.12.22 - 11:41
    bigfoot
    Posts: 510 from 2003/4/11
    I tried Tux Racer, and the menu there seems kinda empty even with the previous TinyGL update. I haven't tried MorphOS 3.17 yet. Do you know when it last worked right?
    SoulFu unfortunately crashes on startup for me, also with the previous TinyGL update. Does it run for you? If so, could you give me a screenshot of what doesn't render right, and with which version of TinyGL it last did render right, if you can find out? That'd help a lot :)
    Ri-Li's menu indeed seems somewhat broken here, but it also looked broken with the previous TinyGL update :) However, the problem looks like some modulo problem with certain texture data, so I'll check that one out. Edit: Took a quick look, and Ri-Li doesn't seem to use TinyGL for rendering at all. Whoops.
    Fade To Black I unfortunately don't have the data files for. I don't suppose they're freely available?
  • »19.12.22 - 15:12
    Papiosaur
    Sorry, i don't know, i will try with MorphOS 3.16 and old version
    I've send you a mail with a screenshot :-)
    ok, thanks to have tested it.
    I've have send you another mail about it.
  • »19.12.22 - 18:07
