Best Amiga NLE video editor
  • vox
    vox
    Posts: 616 from 2003/11/24
    DJ Nick also asked for most advanced Video editor on Miggy. Movie Shop came to my mind,
    but DraCo ex parent does not reply.
    Thats all thanks for all the help.
  • »16.10.22 - 00:43
    Tcheko
    Posts: 544 from 2003/2/25
    For having used some NLE software from the past, afaik, there is nothing with GUI for editing video on MorphOS.
    Still, nothing is impossible if you're brave enough. You can perfectly use ffmpeg in command line mode and do NLE with it.
    Cumbersome? Yes. Can do the job? Yes.
    Edit for a more targeted answer at Amiga legacy:
    All NLE software on Amiga was tied to the presence of a Zorro card. MovieShop was used with the VlabMotion for example, Broadcaster Elite with its eponymous hardware. And the most famous of the most famous was the Video Toaster from NewTek which were only available in NTSC standard. Nothing of all this gonna work with MorphOS unless maybe if you're using an Amiga4000 + CSPPC.
    [ Edited by Tcheko 16.10.2022 - 08:07 ]
  • »16.10.22 - 03:53
  • vox
    vox
    I believe DJ Nick is too fancy for this :) is there a FAQ of FFPMpeg commandns or video tutorials?
    Wasnt Video Toaster software freed of hardware?
    https://www.discreetfx.com/DownloadToaster.html
    Theorectially, would Movie Shop work on A3000 or A4000 witj Vlab?
    https://www.ebay.ie/itm/171253099936
    Would DracoMotion help?
    There is even Toccata on sale.
    I ve got MovieShop 4.6, but its DraCO only
    There is version 5 for casablanca
    https://amigavideo.net/casablanca-user-training-tape/
    So no way to somewhat redirect to use RTG and AHI :(
    And I found this strange video
    https://fb.watch/gbpseCfEDg/
    https://m.facebook.com/watch/?v=349389056433983&paipv=0&eav=AfZaRllPvV2jldruVaLQ9wMTpPnqPDi5lwpP7MCEl28Sba9zIbE6786sMpy_jQof2vU&_rdr
    But it confirms sad above
    Casablanca stull exists
    https://www.macrosystem.us/Casablanca_4_Models_2022_and_23.php
    But today most of software can be purchased separately
    P.S. I see in this thread https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9640&forum=3
    Bldener on MOS is suggested
    DiscreetFX seems promising IF he is for real
    https://www.discreetfx.com/amigaproducts.html
    [ Edited by vox 16.10.2022 - 09:10 ]
  • »16.10.22 - 05:06
    Tom01
    Posts: 187 from 2009/9/20
    You can edit videos with Blender.
  • »16.10.22 - 17:10
    Posts: 2095 from 2003/6/4
    On my 2 do list is a simple video cutter/editor: An external GUI for mencoder done with Hollywood by using the AVCodec plugin.
    I.e. the idea is like that: the "editor" would by done by using Hollywood with AVC doing the actual video output within the program. But the final cutting/joining/rendering would be done by mencoder (the hollywood program would then just start mencoder with the according parameters). But job, family life (pretty stressy since the wife suffers on long Covid for a year now...) and a private research project (long covid related) puts that on hold for the next time.
    The program would be pretty limited in it's possibilities though (no effects), although mencoder does offer quite some options. Maybe I'll find some time during the XMAS holidays...
  • »16.10.22 - 20:40
  • rob
    rob
    Posts: 148 from 2008/7/22
    There's Ktadd's VideoClipper but it's OS4 only.
  • »16.10.22 - 21:29
  • vox
    vox
    Any chances of port?
    What About Movie Shop, could we obtain sources and redirect to AHI and RTG?
  • »17.10.22 - 12:09
    Posts: 848 from 2007/10/23
    Movie Shop is already RTG because of DraCo.
  • »18.10.22 - 17:58
