Is there a port of "Protrekkr" or similar app?
    Elowan
    Posts: 214 from 2011/4/18
    hi there,
    I would like to use Protrekkr - there AROS, OS4, mac, linux and even a windows version of it - but no MorphOS port? maybe I am searching the wrong area of the internet or it just has not been done?
    Maybe there is a clone or alternative around?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »09.09.22 - 15:48
    Samurai_Crow
    Posts: 198 from 2009/12/10
    The source is on GitHub if somebody wants to take a crack at it. I think it needs SDL2 and the system headers since TinyGL and AHI are already included with the OS.
  • »09.09.22 - 17:10
    beworld
    Posts: 683 from 2010/2/10
    @Samurai_Crow No need PowerSDL (SDL1)
    I adapt and built it to MorphOS, i use AROS AHI, seem working well... dont really test...
    Can you test ?
    https://www.morphos-storage.net/upload/test/protrekkr_2.6.3.lha
    My MOS ports
  • »10.09.22 - 03:53
    Elowan
    WOW that´s totally awesome - what a great community :)
    Thank you so much for this, beworld / Papiosaur !
  • »10.09.22 - 08:56
    Intuition
    Posts: 1116 from 2013/5/24
    I ported this to MorphOS in about 2014.
    I’ll see if I can get my Powerbook to boot and rebuild the latest version if you want?
    https://16-bits.org/pt2.php
  • »10.09.22 - 14:24
    tolkien
    Posts: 585 from 2013/5/29
    Can you test ?
    I have quick tested it but can load a file. Seems all directories are locked.
  • »10.09.22 - 15:09
    tolkien
    Storage version
  • »10.09.22 - 15:41
    tolkien
    I have reinstalled it and yes, I can load a file but if click in parent directory i cant enter in any other directory as they are marked as locked
  • »10.09.22 - 16:40
    beworld
    @tolkien i confirm, i check
    My MOS ports
  • »10.09.22 - 16:44
    Papiosaur
    Posts: 2612 from 2003/4/10
    Here i have modules/old and samples/Roland TR-808 and samples/Roland TR-909 as "locked", maybe because MIDI support is desactivated ?
    I load modules .ptk and play it
    [EDIT] Exact, if i do parent, all drawers are locked, even Protrekkr drawer...
    [ Edité par Papiosaur 10.09.2022 - 21:26 ]
  • »10.09.22 - 17:14
    beworld
    i found problem, i re-upload new version soon.
    My MOS ports
  • »10.09.22 - 18:34
    beworld
    You can re-test i update archive.
    Thanks
    My MOS ports
  • »11.09.22 - 03:20
    Piru
    Posts: 622 from 2003/2/24
    There was some discussion that readdir() in MorphOS libnix would be in error due to not returning "d_type" correctly. However, returning DT_UNKNOWN is valid and according to POSIX specification.
    Here's a proposed fix to the protrekkr code (which is probably very similar to what was done already anyway):
    https://github.com/hitchhikr/protrekkr/pull/9
    I've now also implemented returning "d_type" to libnix readdir(). This new libnix version will be released as part of the next SDK release.
  • »11.09.22 - 12:48
    beworld
    @piru thanks you !
    My MOS ports
  • »11.09.22 - 14:43
    Elowan
    awesome, thanks for fixing it! I also got the locked folders issue with first version
  • »15.09.22 - 13:24
    Elowan
    SOLVED:
  • »15.09.22 - 13:36
