Quick Format
    Hawk
    Posts: 204 from 2003/12/29
    I formatted it using Quick Format ... is it safe to work with the disk having it formatted like that?
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »17.04.04 - 07:08
    Thomas
    Posts: 31 from 2004/3/31
    Yes, always. There is no need to do a full-format.
    Bye,
    Thomas
  • »17.04.04 - 09:32
    Posts: 902 from 2003/3/4
    Full format is not necessary for hard drives, and doesn't make much sense either. Harddisks usually have an on-disk buffer, so verify requests will just read the data from that buffer and so can't check if the cylinder has been formatted properly anyway.
  • »17.04.04 - 12:01
