Posts: 1615 from 2012/11/9
MorphOS itself and the file-systems it supports don't allow partitions to be shrunk without losing the data on the partition you are shrinking/modifying, AFAIK.
You can 'supposedly' shrink a Mac HFS+ partition via MacOSX, without affecting the data on the partition, but I've never found that to work that successfully, if at all.
