UltraGelb (#amigazeux) presents Lupe V2.0!
    Posts: 918 from 2004/1/24
    The Mellow Yellow #amigazeux coder extraordinaire presents Lupe V2.0 for both Amiga 68K and MorphOS. It's a magnifying glass.
  • »24.06.22 - 15:00
    Posts: 1090 from 2004/9/23
    Papiosaur wrote:
    Just tested ! Nice tool with many features.
    It slow the mouse speed if i upsize the window but i think it normal because it's a high resolution in the window.
    You can compare easy the performance with the tool "Zoom", which gets delivered with MorphOS.
    It basically does the same as "Lupe" with a slightly different feature set. I personally like that the Zoom window itself is invisible to the zoom, so no recursive zoom, when enhanced layers are enabled.
  • »25.06.22 - 22:25
    Posts: 12543 from 2003/5/22
    Sounds similar to Lupe v2.0:
    "On MorphOS the Lupe window can be excluded from being magnified in its own window"
  • »26.06.22 - 10:30
