CheckItOut will not close with the latest MOS 3.16
    matt3
    Posts: 785 from 2004/2/10
    First, I would like to thank the MOS Team for the best version update I can remember! This version is much more stable and tidy, I use it as a daily driver and I really noticed the increased stability and improvements.
    My finance program that I have used forever on MOS and has always worked perfect, now with the latest version when I quit the application it closes all the windows (check, loans, accounts, etc) but it will not close the window. This worries me because the software constantly writes data and there is no save command and I don't want to lose my work. Sometimes it locks up when using the drop down menu.
    Any help would be appreciated.
  • »13.03.22 - 19:50
    Posts: 3337 from 2003/3/5
    Where can I find it?
  • »13.03.22 - 21:00
    Posts: 848 from 2007/10/23
    I suppose you mean "but it will not close the screen".
    How about to copy the cio file in-between?
  • »13.03.22 - 21:05
    matt3
    Hey Polluks,
    I should clarify.
    I can load and begin using the software as normal.
    Sometimes when I right click to select a menu item it will lock the system.
    When I go to File/Close to quit the program all the windows open in the program close and the main application stays open.
    Regards,
    Matt
  • »13.03.22 - 21:27
    It looks like the app quits without closing all of its windows. I'll investigate some more.
  • »14.03.22 - 00:40
    So I have tested it under 3.15 and it won't close either if you leave some of the windows open as you quit (like Preferences). Not sure when I'll hate the time to test it with AmigaOS 3.1 to compare...
  • »14.03.22 - 11:00
    matt3
    Interesting, it closed just fine for me in all prior versions of MOS. The only interesting item was that in 3.15 the help screen would automatically open when I loaded it.
    Strange. Really appreciate you taking a look. If there is anything I can do to help the process, let me know.
    Maybe I could send you my data file and licensed version of the software? I'm loading the licensed version of the .030 version.
    [ Edited by matt3 14.03.2022 - 10:16 ]
  • »14.03.22 - 13:15
