Problem Wayfarer and download
    Papiosaur
    Posts: 2623 from 2003/4/10
    Hi all,
    when i download many files with Wayfarer (for example 2 or 3 simultaneously), i have no progression bar (for one file too) and when i extract or move one file finalized others files stop download...
    Any ideas ?
    Thanks
  • »19.04.21 - 09:53
    Posts: 3337 from 2003/3/5
    Not sure I understand. Can you take a video?
  • »19.04.21 - 14:15
    And what does it show in the Downloads tab?
  • »19.04.21 - 15:36
    tolkien
    Posts: 585 from 2013/5/29
    Menu->View/Downloads (I think it is cos I use it in Spanish).
  • »19.04.21 - 16:50
  • »19.04.21 - 16:55
    Well, could you take a video of downloading files from morphos-team.net? Start a 3.15 download and SDK download and then go to the Downloads tab.
  • »20.04.21 - 11:10
    tolkien
    I hava that problem when I download from storage. Dont know if it is related to other websites cos I download mainly from storage.
  • »20.04.21 - 13:54
  • rms
    rms
    Posts: 606 from 2004/11/27
    Papiosaur wrote:
    It work ok on the MorphOS Team website.
    Seems to be a problem from the storage maybe ?
    I did try exactly the same you did (I think I understood your video), which is, from www.morphos-storage.net I chose Top 20
    then I started to download 3 files: MPlayer_1.4-20200619.lha + OpenTTD_1.11.1.lha + ZGloom_0.3.0.lha
    all at the same time and all download ok here.
    As soon when the 1st lha finished downloading, while the other 2 are still in progress, I opened this Lha with double click and started to copy the content to RAM:
    no problem, it copied and during the copy process the other 2 lha finished to download.
    I think it works as it is expected to, at least here.
    Best regards
    Christoph
  • »20.04.21 - 13:57
  • K-L
    K-L
    Posts: 46 from 2020/11/17
    Yes, Wayfarer struggles ont Morphos-storage : it hangs when trying to download multiple files.
    Odyssey works ok when downloading multiple files.
    [ Edité par K-L 20.04.2021 - 20:03 ]
    PowerMac G5 2,7 Ghz / Radeon 9650 / MorphOS 3.15
    AmigaOne X1000 (unused ATM)
  • »20.04.21 - 16:02
    Does it happen if your OS is in English?
  • »20.04.21 - 17:25
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    It hangs for me occasionally (yes, English language). It tends to timeout on larger files when doing multiple downloads on that particular site.
    IKE
  • »20.04.21 - 17:42
  • K-L
    K-L
    No, since I could download without any problem many files with Odyssey.
    BeWorld knows about this and I don't think it comes from the server side, maybe a bad handshaking between Wayfarer and Mophos-storage server.
  • »20.04.21 - 18:10
    Could be a difference between HTTP/1 and HTTP/2... Still, that would be a server issue.
    [ Edited by jacadcaps 21.04.2021 - 14:14 ]
  • »21.04.21 - 10:14
