ssh2fs & passphrase
    Posts: 848 from 2007/10/23
    ssh works
    Enter passphrase for key '.ssh/id_rsa':
    Welcome to Ubuntu 20.04.2 LTS (GNU/Linux 5.4.0-65-generic x86_64)
    but ssh2fs (mounting the same connection) still wants a pw (of course I have used the PW option, but a passphrase seems not to be equivalent to a password)
    Remote says: SSH-2.0-OpenSSH_8.2p1 Ubuntu-4ubuntu0.1
    Enter password:
    Authentication by password failed.
    Authentication failed (username/password)
  • »03.02.21 - 05:32
    Posts: 478 from 2019/5/9
    user/password and ssh-key are different authentication methods.
    Ssh-key can be secured by passphrase (but it is not equal to password).
    You can have different authentication methods for ssh and sshfs ( and for every other ssh connection).
    If you want use ssh-key for sshfs, you have to use "pk" parameter - see SShFs and params.
    And if you wand paswordless login, I recommend you made key without passprase.
    I don't know, if in MorphOS are such things like ssh-agent and keychain, which helps you automatically manipulate keys with passphrase. I can check it at home.
    [ Edited by sailor 03.02.2021 - 09:37 ]
  • »03.02.21 - 06:25
    Of course, thank you very much, Sailor.
    But it still does not work:
    > ssh2fs root@XXX.XXX.XXX.XXX N: pk verbose
    SSH2FS by Leif Salomonsson 2012-2019. (Compiled Dec 30 2020 04:10:47)
    libssh2 version: 1.9.0
    Connecting to server..
    Authentication methods available: publickey,password
    Authentication by public key failed!
    Callback returned error
    Closing down.
    [24] [ssh2fs] [Open] [USE_LIBSSH2_KNOWN_HOSTS] [Lesen] [Fehlgeschlagen]
    [25] [ssh2fs] [Open] [DH3:Gits/.ssh/known_hosts] [Lesen] [OK]
    [26] [ssh2fs] [Open] [DH3:Gits/.ssh/id_dsa] [Lesen] [Fehlgeschlagen]
    [27] [ssh2fs] [Open] [DH3:Gits/.ssh/id_rsa.pub] [Lesen] [OK]
    [28] [ssh2fs] [Open] [DH3:Gits/.ssh/id_rsa] [Lesen] [OK]
    [29] [ssh2fs] [Open] [DH3:Gits/.ssh/id_rsa] [Lesen] [OK]
    [30] [Shell process] [Open] [shellppc.prefs] [Lesen] [Fehlgeschlagen]
  • »03.02.21 - 08:02
