Test of the new ibrowse 2.5.3
    Brumiga
    Posts: 277 from 2004/4/3
    Hello everyone,
    I saw on amigaimpact as well as on the ibrowse site that a new version, 2.5.3, had just been released on June 10.
    I told myself that I would try it well to see what it gives. I download it and then install it on my hard drive. Already there small problem, the archives or the installation directories unarchived in ram or elsewhere do not want to be erased, ambient indicates them to be always in use. Then I launch it and I load my link file, I click on links at random but alas it is a disaster. Problem with sites using css that ibrowse cannot handle and display correctly. Only obligation and aminet are displayed correctly. Let's see this disappointing result I stop the test there. I want to delete the created directory but once again ambient indicates to me that this one or parts are still in use. After a reboot I can delete ibrowse. But then the default disk and directory icons are no longer correct. They are by default. I opted to use a backup of my system that I have on an external hard drive and find my configuration. I could also have looked for what could have been changed or replaced without my wanting or wanting it.
    Here, it was the account of my essay of the last ibrowse. If in turn you want to try it because you think you can do better than me so. But then good luck in advance ...
    Brumiga
  • »14.06.20 - 14:53
    Posts: 903 from 2003/3/4
    Being unable to delete is probably due to open library filelocks or assigns. MorphOS cannot delete them because they really are still in use.
    That said, why exactly would you want to use IBrowse in 2020? I used to like it in its day, but it's more or less a simple html viewer, not a browser. Lack of CSS is a killer alone, and I'm sure the javascript parser hasn't advanced much from the late 90s.
  • »14.06.20 - 19:44
    Furvert
    Posts: 83 from 2004/4/20
    Actually there was a major rewrite on it to the extent he is charging for it. (There is a discount I think for upgrading)
    As I understand it there is no MorphOS native but the Classic Amiga version should work. CSS is there but I don't know how complete it is... Personally I'm waiting on this one, even for my old A1200. Let the kinks and bugs get checked and see what we have. MUI5.0 is having issues with it seems and it requires AmiSSL 4.6.
  • »14.06.20 - 21:36
    Piru
    Posts: 624 from 2003/2/24
    The changes in actual rendering and standard support in IBrowse have been minimal at best.
    CSS is there
    No it's not. Neither is HTML5, DOM or modern JavaScript. IBrowse 2.x won't have these according to IBrowse website.
    [ Edited by Piru 15.06.2020 - 04:48 ]
  • »14.06.20 - 23:33
    Posts: 12566 from 2003/5/22
    MorphOS-native javascript.library was re-added with v2.5.1.
  • »15.06.20 - 05:13
    NewSense
    Posts: 1618 from 2012/11/9
    Piru wrote: The changes in actual rendering and standard support in IBrowse have been minimal at best.
    Furvert: CSS is there
    Piru wrote: No it's not. Neither is HTML5, DOM or modern JavaScript. IBrowse 2.x won't have these according to IBrowse website.
    Piru is correct, as usual, and it is a disappointing release overall for Classic Amiga users, but it does show that the browser is being supported by its core team, led by Oliver Roberts, to continue to develop, even at a limited pace (though I hope the progress improves), and my genuine hope is that IBrowse v3 does eventually get to see the light of day, with actually useable features for the modern Internet.
    It's basically of little use as it is for modern web-browsing/interacting with websites as the features it needs, that Piru mentioned, are just not in the program currently. Having said that, I have paid for the upgrade to v2.5 to show some support to Oliver Roberts and the others involved with IBrowse to see if that required progress can be realised, but it will be a big ask, to see that happen.
  • »15.06.20 - 22:00
