Posts: 1386 from 2010/1/6
That's a feature from Ambient - so it's active when Ambient is loading - not earlier.
If you want a earlier "bootjingle" you need to start a player in Mossys:s/Startup-sequence like
run playmp3 >NIL: yoursoundfile
But be warned: You must know what you are doing, if you modify startup-sequence in MOSSYS: !!
playmp3 is a MorpOS-native dos-command which I have downloaded anywhere - don't find it at moment. If you don't find it, give me PM - I'll send it to you......
[ Editiert durch Amigaharry2 20.05.2020 - 22:13 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
