GenesisPlus bug
    Solo_Kazuki
    Posts: 194 from 2006/7/23
    Hello
    I'm using joypad so i omitted this bug before, but one of my pals is using only keyboard and he found one bug. In short [DOWN] mapped on keyboard as down arrow is "jamming". It means even if you depress down arrow, down direction is still active as key would be still pressed.
  • »27.04.20 - 15:48
    Solo_Kazuki
    One more thing. Is possible to make bigger screen for Game Gear and Master System games?
  • »28.04.20 - 14:39
    realstar
    Posts: 298 from 2003/2/24
    Seems a bad config file got put in the last release as I was testing some things. For a quick fix copy this into 'GenesisPlus/prefs/'
    https://realstar.neocities.org/inputp1.config
    There is a duplicate value in the input config that is mapped as the key down release causing things to stick. Will fix for next release. Can also check on disable borders for GameGear/SMS.
  • »28.04.20 - 14:55
    Doffo
    Posts: 508 from 2010/10/14
    Realstar rules! :)
    YUUUP!
  • »28.04.20 - 15:12
    realstar
    Update v2.1 now available: GenesisPlus
    I added a double sized scanline mode and border option. The double sized scanline mode depends on the Ambient screen resolution being high enough to support this. 1024x768 is enough for GameGear 2x mode with border disabled. You will need at least 1280x960 for SMS or Genesis/MegaDrive 2x mode. If screen resolution is not enough to fit it will revert back to normal scanline mode.
  • »30.04.20 - 01:33
    Solo_Kazuki
    Thanks a lot!
    One thing that i can nag is not exactly 1:1 ratio when not using borders. I think there should be little borders left to keep aspect ratio. But it's just nagging ;-)
  • »04.05.20 - 13:31
    Solo_Kazuki
    Ok, I found one bug with GameGear saves which is similar to GameBoy saves bug. It's about removing not extension but four symbols when .GG is only three, so name of save file is without last letter (so e.g. for Game1.GG and Game2.GG saves would be just one Game.sav).
    [ Edited by Solo_Kazuki 05.05.2020 - 16:23 ]
  • »05.05.20 - 12:22
    Solo_Kazuki
    Hello
    Sorry for asking, but could You at least fix this saves bug? Adding "ratio borders" (similar as in mGBA for GB/GBC games)is of course only optional.
  • »20.05.20 - 15:04
    realstar
    I added the sram filename fix and also added a check to see if the game has a modified sram so it should no longer save sram files for games that are not using the sram. This means there may not be an sram file until you save your game at least once on some titles.
    v2.1b : GenesisPlus
  • »21.05.20 - 01:25
    Solo_Kazuki
    Thank You very much! Now saving is working fine.
  • »21.05.20 - 15:23
