Disable automatic monitor detection
    Cego
    Posts: 738 from 2006/5/27
    Is there a way to disable morphos' feature to automatically detect monitor specifications and adjusting of screenmodes?
    I am using an HDMI splitter for simultaneous usage of my monitor and HDMI grabber (for streaming).
    But as soon as i activate the splitter MorphOS will detect new screenmodes which results in an "out of range" on my monitor.
    I'll need the screenmodes for my monitor permanently.
  • »03.05.20 - 15:43
    Posts: 3326 from 2003/3/5
    You can delete the ddc.library. Just remember to do this after updates.
  • »03.05.20 - 15:54
    Posts: 902 from 2003/3/4
    Delete MOSSYS:Libs/ddc.library
    Echo meh >MOSSYS:Libs/ddc.library
    Protect MOSSYS:Libs/ddc.library -rwed
    That should protect you from updates replacing the file.
    Or, alternatively, completely break the MorphOS installer, depending on how smart it is...
  • »04.05.20 - 19:22
    Given that there's no provision for ddc.library in IWizard's update scripts, your advice isn't likely to change anything. The installer replaces the whole MorphOS directory and only a few select files are copied back from the old one.
  • »05.05.20 - 09:39
