E-UAE - WHDLoad F12 key conflict
    Posts: 40 from 2019/9/5
    Hello everyone,
    I installed WHDLoad Opener to run the WHDLoad games directly from Ambient, and it is working amazingly well. The only issue I have is the F12 key binding. E-UAE is using it for almost every keyboard shortcut where WHDLoad is using it for quitting the game.
    Is it possible to remap F12 on either E-UAE or WHDLoad?
  • »20.12.19 - 13:45
    Korni
    Posts: 473 from 2006/2/23
    I've set WHDLoad to use F12, reason for that is WHDLOpener reads only the slave tooltype from the icon. All other tooltypes are ignored. By default WHDLoad uses * AFAIR. I ran into a game that needed this key and honestly I had no idea E-UAE uses F12 as I never needed it.
    TLDR: Quitkey can be set in S:CallWHD.dos. It uses rawcode as an input parameter or you can simply remove this option to use defaults.
    [ Edited by Korni 20.12.2019 - 18:00 ]
  • »20.12.19 - 14:59
    Actually I only need EUAE shortcut keys for saving/loading states. As far as I understand, the default shortcut for this is F12+F5.
  • »20.12.19 - 16:41
    Posts: 902 from 2003/3/4
    You can also change the quitkey on WHDLoad with a tooltype on the slave.
    There's a table of rawkeys in the docs.
    (Edited: QuitKey takes rawkeys.)
    [ Edited by KennyR 21.12.2019 - 20:51 ]
  • »21.12.19 - 19:49
    Thanks. I'd tried actually, but somehow it didn't work. WHDLoadOpener overrides the custom tooltypes.
    As Korni suggested, I edited S:CallWHD.dos and it worked perfectly.
    Thanks.
    By the way, if someone needs the Rawkey codes;
    http://whdload.de/docs/en/rawkey.html
    [ Edited by retrolinuz 23.12.2019 - 10:51 ]
  • »23.12.19 - 14:36
