Playing audio CD
    asrael22
    Posts: 453 from 2014/6/11
    Hi.
    Which CD-Player would I use?
    I tried Jukebox with drag&drop the tracks from a CD.
    Also I tried "cdplayer2.lha". But for some reason it doesn't find the CD rom drive which is CDDA0:
    Cheers,
    Manfred
  • »12.09.19 - 17:10
    Posts: 2094 from 2003/6/4
    asrael22 schrieb:
    Hi.
    Cheers,
    Manfred
    I use Songplayer.
    But in most cases I don't play cds directly anyway, but instead rip & convert them immediately with Ripper to RAM:, and decide after listening wether or not I keep the files.
  • »12.09.19 - 20:38
    Posts: 2220 from 2003/2/24
    I've also used Songplayer, but mostly also rip them to MP3 and play with Jukebox then.
    IIRC the Ripper program wasn't acting completely clean way (makes a hit), but MorphOS comes with a good ripping program itself too: Flacapella
  • »13.09.19 - 02:49
    asrael22
    Zylesea wrote:
    asrael22 schrieb:
    Hi.
    Cheers,
    Manfred
    I use Songplayer.
    I'd like to put in my old CDs and play them as is.
    Is "CD Player" known to not work anymore?
    http://aminet.net/package/disk/cdrom/MOS_CDPlayer
    Manfred
  • »13.09.19 - 04:18
    Manfred
    Being an old man who remembers playing vinyl records in my youth, I can understand the desire to be able to just pop a CD into your MorphOS computer, and have it play all tracks of the CD, without needing to interact with it at all (just like dropping a record on the player and moving the needle to the beginning of the record, or if it was a high end player, pushing a button to have the needle arm move to the beginning of the record automatically). But now I would rather save the wear and tear on my original CD's, and just rip the tracks to files, and play them that way, saving the CD for a time when I might need to rip the files again, if my hdd, or ssd gets corrupted, or otherwise damaged, or if I just want the files on a different computer, and it is inconvenient to copy the files across. Just my 4 cents (usually 2 cents, but I'm always long winded).
  • »13.09.19 - 05:19
    I think this older version of "CD Player" just puts CD drive to play the CD in physical way, you'd need the drive to wired to some audio system to hear anything. This is pretty uncommon setup nowadays, and I don't know if that could be done in Macs at all. In old times you wired your CD-ROM drive to your audio card which mixed the inputs to the single output and then you heard them just like played with a stand-alone CD player device.
    But there's a newer version of it available here: http://amigazeux.net/cdplayer/down.php
    This 2.1 version allows you to stream the CD data software wise to your system's audio output (through AHI), so it'll work on all setups. Songplayer also does this, so that's why many of us use it.
    BTW. you have to configure these programs to use the actual device driver (ide.device for example), not the mounted virtual audio CD (like CDDA0:). If your CD drive is connected as a slave to the primary IDE port, then the device would be ide.device unit 1.
  • »13.09.19 - 05:28
