Speed of paste
    Posts: 848 from 2007/10/23
    Hi!
    How do you change the speed of paste? I would like to paste "slower" with RemoteShell because of lag in response.
  • »20.06.19 - 06:23
    Posts: 3337 from 2003/3/5
    There's no such thing as a speed of paste. The way pasting works, it goes through several layers that enforce a maximum length of the paste. Unfortunately changing this requires quite a bit of work.
  • »21.06.19 - 04:23
    I see.
  • »21.06.19 - 13:19
    It is actually just typing this into a terminal and the ssh backend ends up not receiving everything on time to avoid overflowing the terminal input buffer (if I remember right).
  • »21.06.19 - 16:01
