ANR misbehaves on MorphOS 3.11
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Don't know if has been previously reported or if it's just my setup. Searched the forum and din't find any clue but ANR upon exit (while on idle or while playing a song), consumes about 95% of available system ram, system goes stalling for 2-3 seconds then ram gets available again. This behavior is 100% reproducable. It can consume easily up until 1.6GB ram making it the single most ram hungry proggy on MorphOS :P
    Seriously though, ANR rocks with its sexy skin, on/off transprency, scream bar and I would like to continue my co-existance with it.
    In tha past I had noticed that ANR was again displaying same misbehavior under certain circumstances (ie existing while RDesktop or VNC was active or similar stuff, can't exactly recall right now), so I am not sure absolutely sure if it's because of system or not. Anyone willing to take a short test with it?
  • »01.06.19 - 06:41
    Posts: 899 from 2003/3/4
    There are known bugs in the last release version of ANR that corrupt memory on exit. I guess 3.11 is just more touchy about it.
    Gelb reappeared for a while, made some fixes, and removed a whole load of MorphOS-dependencies so it ran on 3.x again (because it hadn't for a while). It was still very far from release though, before work took back all his time.
  • »01.06.19 - 18:01
    Jeckel
    Posts: 133 from 2007/3/11
    Cool_amigaN wrote:
    [...] consumes about 95% of available system ram, system goes stalling for 2-3 seconds then ram gets available again. [...]
    I have this behavior on my PowerBook but not on my Pegasos 2. Both of them using the same MorphOS and ANR version. What I noticed, is that resetting ANR playlist solved the issue.
  • »03.06.19 - 06:58
    Cool_amigaN
    Hmm, did what you suggested but without any success :/
    Come on guys, I am not the only using ANR, can anyone else check ANR with latest MorphOS? If it's my setup I must invistigate further or re-install because this keeps happening 100% of times tested..
  • »14.06.19 - 17:15
    Posts: 2206 from 2003/2/24
    You're probably the only one who still dares to use it after it's been admitted that it trashes memory ;) It's always been crashy on my setup in other things too, like playing mp3 files from HD and I always get it crashed somehow, so haven't been using it ever actually. I rather not do even any tests with it... won't risk it to see the day it corrupts SFS or something crucial... There are other mp3 players (Jukebox and 3rd party) and RNORadio for streaming.
  • »15.06.19 - 03:18
