Hex2 - my little calculator
    Posts: 139 from 2015/3/31
    Hex2 is a little calculator I wrote long time before, mainly for coder and scientist (so... me :-P)
    it supports variables and have now a simple MUI GUI.
    More Informations and Download: https://blog.alb42.de/2018/11/09/full-hex2-mui-port/
    Have Fun.
  • »09.11.18 - 18:11
    Posts: 902 from 2003/3/4
    Well done. Anything that supports BODMAS and algebra is well worth having. Hex2 is the kind fo tool I'd have killed for when I was at high school.
    Yeah, most people won't comment, but don't let that put you off. Tools like this are the kind of thing you never need... until you need them. Then you really need them.
    Now get it to solve polynomials...
    (just kidding :)
  • »10.11.18 - 14:38
    Thanks,
    I use it a lot (for Linux/Windows), its useful for programming ;) when you often have to deal with hexadecimal and binary numbers. For SPI/I2C communications a bit shift of your result only can be noticed with such a tool ;)
  • »10.11.18 - 16:17
    Posts: 608 from 2003/4/11
    Well done.
    Now add some modulo function that isn't limited to 32 bit integers and you could even calculate IBAN checksums with it :)
  • »10.11.18 - 16:36
    cyfm: the problem is not the 32bit integer the problem all internal calculations are done with extended or double floats which is not exact enough to do IBAN mod ;)
  • »10.11.18 - 17:22
    little update from wishes and reports
    Hex2 Version 0.2
    new:
    - added swap() - swap endianess
    - integer division '\' and integer modulo '%'
    - Overflow bugfixes
    https://blog.alb42.de/2018/11/11/hex2-0-2/
  • »11.11.18 - 08:23
    igracki
    Posts: 469 from 2003/2/24
    Nice!
    Two little bugs, the upper listview always jumps to the top and the string gadget isn't in the CycleChain.
  • »11.11.18 - 11:31
    thanks for feedback.
    are you sure? for me it always jumps to end ... at every input
    I do a MH_Set(Obj, MUIA_Prop_First, MaxInt); after every new line added which seems to work nicely in MorphOS 3.11 and 68k MUI 3.8
    Yes, I forget about the cycle chain, I will add it next time.
  • »11.11.18 - 12:23
    igracki
    Here is a short video showing it.
    Why don't you use MUIA_List_First?
  • »11.11.18 - 13:03
    strange...
    hmm ok I changed to it (not worth to make a new version number) could you download it again and see if it makes any difference (the cycle chain should also work)
  • »11.11.18 - 13:44
    igracki
    Thanks, now it works!
    But now the Clear button isn't anymore in the cycle chain;)
  • »11.11.18 - 14:42
    igracki
    There is also a hit if the Hex2.ini file couldn't be written!
    F.e. if you start Hex2 from inside the archive!
  • »11.11.18 - 14:52
    Fixed both.
    Thanks for the reports.
    The crash is a little bit bad... not sure how this can happen, I have no way to check that... usually a exception should happen there... so somehow I got a handle on this ini file but then a crash when try to write it. hmm,
  • »11.11.18 - 16:28
