RDesktopMUI
    matt3
    Posts: 749 from 2004/2/10
    Hi All,
    Trying to get RDesktopMUI working without success. Same settings work fine on a pc.
    Looked at snoopium and 5 fails take place.
    Background CLI ShellPPC.prefs
    Rdesktop Sys:data/zoneinfo/gmt
    Rdesktop Sys:data/zoneinfo/posixrules
    Rdesktop Sys:data/zoneinfo/us/eastern
    Rdesktop ENV:sys/net/passwd
    Any ideas?
    Thanks!
  • »17.08.18 - 22:25
    matt3
    jPV wrote:
    Works fine here. Where it stops and does it give any errors? Have you checked the notes here: https://library.morph.zone/Applications/RDesktop
    Hi jPV,
    Tried that and all the available settings in RDesktopMUI. No luck and no errors other that what snoopium shows up.
    Strange, PC remote desktop connect right away...
    Will keep reading and testing, any suggestions welcome.
    [ Edited by matt3 18.08.2018 - 17:19 ]
  • »18.08.18 - 19:19
    zukow
    Posts: 649 from 2005/2/9
    matt3 wrote:
    Hi All,
    Any ideas?
    Thanks!
    I assume that you are using my version from Morphos iso so
    1) Check exec line for rdesktop in Snoopium
    2) open the shell, change directory to rdesktop one, run rdesktop from shell with the exec line
    3) You can also put tooltypes to rdesktop icon to directly call connection.
    [ Edited by zukow 19.08.2018 - 01:04 ]
  • »18.08.18 - 21:03
    Posts: 891 from 2003/3/4
    If you are trying to connect to a Windows 10 PC host, you may have to change a setting in the host Administrative Tools -> Remote Desktop Services - Remote Desktop Session Host Configuration -> Connections -> Properties -> General.
    Make sure "Allow connections only from computers running Remote Desktop with Network Level Authentication" is off. It is more secure, but only Win10 and Win8 PCs will be able to connect to it.
  • »19.08.18 - 14:03
