How to change the Ungly IBrowse Fonts
    liquidbit
    Posts: 408 from 2003/10/12
    What I hate the most is the IBrowse Fonts.
    They look Big Bold and Ugly.
    Is there a way to change them?
  • »22.03.04 - 17:28
    Black_Eagle
    Posts: 70 from 2003/6/5
    Yes. Just get a bunch of TrueType Fonts off the net or a PC and edit the settings. I have all the standard web font here so it looks like on my PC browsers. Like Arial, Verdana, Times New Roman, Wingdings and a bunch of others.
    There are some pages on the Internet where you can compare with images of the fonts, so you can set the sizes ok. It takes some time if you want it to look good.
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »22.03.04 - 17:32
    marcik
    Posts: 268 from 2003/4/12
    Menu -> Preferences -> Settings...
    Then
    HTML -> Fonts
  • »22.03.04 - 17:33
    liquidbit
    hmmm..I have the demo version.
  • »22.03.04 - 18:06
    Estrayk
    Posts: 142 from 2003/12/30
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »22.03.04 - 21:17
