Starting Applications Automatically at Boot
    Posts: 12 from 2013/9/22
    I would like to configure MorphOS to automatically start VNC Server at boot. Is there an easy way to do this?
  • »22.09.13 - 13:17
    Posts: 2561 from 2003/2/24
    a) start it from s:user-startup
    b) put it into the WBStartup folder
  • »22.09.13 - 13:46
    Yasu
    Posts: 1724 from 2012/3/22
    Putting it in sys:wbstartup maybe?
    My MorphOS blog
  • »22.09.13 - 13:46
    boot_wb
    Posts: 874 from 2007/4/9
    Simplest way:
    Open the vnc application drawer and drag (or copy/paste) it into sys:wbstartup.
    (If you're viewing the application folder as a list, with 'all files' showing make sure to copy its icon file 'vncserver.info' aswell).
    Other ways include launching from the s:user-startup script (which is automatically run at boot time).
    Hope you enjoy your new MorphOS system. :-)
    EDIT: Damn, I'm slow today.
    [ Edited by boot_wb 22.09.2013 - 17:02 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »22.09.13 - 14:01
    Thanks for the quick replies. I am really liking this OS as it's super fast!
    I did copy the icon for VNC to WBStartup and it appears to start fine, but throws an error saying it can't bind to a port :-(
  • »22.09.13 - 15:01
    Yasu
    I hope this is right (I don't have my computer in front of me):
    Start Shell
    Write: ed s:user-startup
    Write at the bottom: wbrun [programs directory]\[program]
    Save file and reboot.
    If it doesn't work: just remove that line again.
    My MorphOS blog
  • »22.09.13 - 16:26
    Intuition
    Posts: 1116 from 2013/5/24
    Start Shell
    It's a / on Amiga/MorphOS/*nix/OSX. The \ is only used on Windows.
  • »22.09.13 - 17:01
    Yasu
    I picket the wrong one by accident. Sorry 'bout that :-)
    My MorphOS blog
  • »22.09.13 - 17:13
    So close, but not quite.
    I entered work:utilities/vncserver/vncserver in the s:user-startup file but it still won't start.
    Funny thing is I can type it in the shell and it starts with no problem. There must be something else I'm missing?
  • »22.09.13 - 17:18
    Yasu
    Did you write "wbrun" first? Or "run"?
    My MorphOS blog
  • »22.09.13 - 17:20
    I used wbrun, sorry, neglected to add that
  • »22.09.13 - 17:23
    Mabo
    Posts: 67 from 2010/5/3
    Hi there!
    Try this:
    bye
  • »22.09.13 - 17:29
    network-startup got it working!
    Thanks.
  • »22.09.13 - 17:34
    Thanks.
  • »22.09.13 - 20:25
    Yasu
    But why did it work on network-startup and not user-startup? That shouldn't make a difference. Anyone have an answer to that?
    My MorphOS blog
  • »22.09.13 - 20:38
    Posts: 2090 from 2003/6/4
    Yasu:
    network startup waits until the network is properly set up which may take a little time.
  • »22.09.13 - 20:44
    Yasu
    Zylesea,
    [quote] network startup waits until the network is properly set up which may take a little time./quote]
    That makes perfect sense :-)
    My MorphOS blog
  • »22.09.13 - 21:35
    bash64
    Posts: 974 from 2010/10/28
    I also use this method with Wetter (the weather app).
    It needs to startup after the network comes up.
  • »23.09.13 - 19:19
    Mabo
    Zylesea,
    Is not true...
    My network takes about one minute or two :)
    [ Edited by Mabo 28.09.2013 - 17:28 ]
  • »28.09.13 - 13:26
    TheMagicM
    Posts: 1220 from 2003/6/17
    bump..
    I did this.. I put it in network-startup but its not working.
    I have a run DETACH system:applications/vncserver/vncserver
    The .png posted above is no longer accessible.
  • »04.12.16 - 23:08
    Posts: 900 from 2003/3/4
    Can't you run it as a Netstack daemon? That's how network services really should be started.
  • »05.12.16 - 16:05
    Korni
    Posts: 473 from 2006/2/23
    It's S:User-Network-Startup now.
    Run >NIL: SYS:Applications/VNCServer/VNCServer
    Just works here.
  • »05.12.16 - 18:20
    Posts: 1089 from 2004/9/23
    Starting with 3.8 (AFAIR) it is "user-network-startup".
    It will wait till network is on. Here it takes around a minute, too sometimes.
  • »05.12.16 - 18:21
    Posts: 12530 from 2003/5/22
    It was 3.4.
  • »05.12.16 - 20:14
    r-tea
    Posts: 317 from 2005/3/27
    "Folder" sounds ugly. Better say a directory or way better a drawer .
  • »06.12.16 - 19:24
