Posts: 2079 from 2003/6/4
r-tea schrieb:
I wonder why Exutil does require MUIRoyale plugin (woun't start w/o it) and SQLMan doesn't?
Both were written with Hollywood using MUIRoyale plugin.
Since a while you can link the plugins into the executables. But this came after my last release of Exutil, hence it requires it to be installed seperately. SQLMan probably has it linked into the binary.
If I do another Exutil release I may link it into the executable, too. It makes the executable bigger though...
