A keymap for Apple keyboard
    r-tea
    Posts: 317 from 2005/3/27
    I use a Mac mini. Recently I changed a typical pc keyboard to an original Apple A1048 german layout.
    What keaymap should I select in system prefs to have all characters I can see on screen corresponding to ones on keyboard keys?
  • »17.07.16 - 18:36
    Posts: 1390 from 2010/1/6
    I use normal German 105-Key -keymap. But you have tu adapt some keys in USB-Prefs:
    in USBprefs/Devices select Apple_internal_keymap. In the opening window select Keyboard (HID-Class). Hid-class prefs window will open. In section keyboard (keyboard mapping) you can assign the right keys to your board-keys......
  • »19.07.16 - 11:46
    Posts: 848 from 2007/10/23
    Especially you should fix the at sign. At least my patch for Swiss keyboards is included.
  • »19.07.16 - 12:17
    Posts: 2581 from 2003/2/24
    Here is the result of me fiddlingwith an old keyboard editor:
    http://www.steamdraw.homepage.t-online.de/Apple110d
    -> not an official MorphOS-keymap
    -> might still be wrong in some places
    -> tested with the aluminium keyboard (the A1048 should have the same layout)
    Copy to sys:devs/keymap
    [ Edited by Kronos 19.07.2016 - 18:38 ]
  • »19.07.16 - 12:34
    r-tea
    Thank you guys.
    I found a keymap editor on Aminet called Keymorpher, but there is no guide in the archive. Do anyone know how to use it?
  • »20.07.16 - 11:51
    I obviouly knew how to use it 10 years ago......
  • »20.07.16 - 14:00
    Posts: 3337 from 2003/3/5
    Be advised that this tool won't produce proper keyboards anymore... you'll likely miss out on features, such as Unicode not working where it's supported, etc.
  • »20.07.16 - 14:13
    connor
    Posts: 650 from 2007/7/29
    Is a new version of this tool in the works?
  • »20.07.16 - 14:19
    r-tea
    Thanks. Good to know. I'll try the tip from Amigaharry or try out the ready to use keymap from Kronos.
    You better ask the author directly: jvovka belnet ru
  • »20.07.16 - 14:23
    r-tea
    Doubled post. Please, remove it.
    [ Edited by r-tea 20.07.2016 - 20:33 ]
  • »20.07.16 - 14:26
    The MorphOS keymaps' sources can be found on our website, so you should be able to modify and produce your own ones from source. Those will have all the required features.
  • »20.07.16 - 14:44
