                Posts: 1424 from 2003/4/13
				I've set this up before and the readme is pretty straight forward.
- Added SpellChecker library support. Dictionaries are expected in that kind
    of path: LOCALE:dictionaries/<language>/base.dic
    To enable spellchecker, use contextmenu in a text/textarea element and
    enable "Check Spelling While Typing".
I did all of this and no go. I enable it and nothing. If I select "choose language" it does nothing. This is a fresh MorphOS install but i did install Pack Chrysalis. Could that have broken something? I don't see any other settings in the main OWB preferences.
Thanks in advance.
-edit- The folder dictionaries is misspelled by Chrysalis pack, now fixed and working.
[ Edited by redrumloa  17.04.2016 - 13:23 ]
