New features in MOS 3.10 Showgirls?
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    It will be interesting to see new features in ShowGirls when 3.10 will be released:
    1) Long awaited support for anim-gif images...
    2) Internal re-entrant cache in order to support very HUGE images like those from NASA 10,000 x 10,000 pixels upto 40,000 x 40,000 and more...
    Thanks for your kind attention.
  • »02.04.16 - 09:22
    deka
    Posts: 136 from 2013/2/12
    I could be satisfied with some bugfixing in first turn...
    [ Edited by deka 04.04.2016 - 15:22 ]
  • »04.04.16 - 05:06
    Posts: 1390 from 2010/1/6
    I'm missing a printout-function (postcript).......
  • »04.04.16 - 11:58
    Raf_MegaByte
    Me too... I just mean of new features OUT of bugfixing as long as ShowGirls bugs are well known by MorphOS developers (as long as many other bugs) but we all known they are pursuing their secret roadways and hidden paths, unknown to mortal uesers eyes, in order to release new versions...
  • »04.04.16 - 12:54
    connor
    Posts: 650 from 2007/7/29
    It would be nice to at least add the latest version of Showgirls to the ISO. It still is an old one, so you have to download the new one separately.
  • »12.04.16 - 12:50
    Posts: 12572 from 2003/5/22
    ShowGirls 1.2 was released in 2009 when MorphOS 2.4 was current. Since then, it was updated as part of MorphOS several times:
    "Updated to 1.2"
    http://www.morphos-team.net/releasenotes/2.7
    "TIFF/PNG/ILBM savers now store the DPI.
    Compression can now be selected for TIFF images.
    http://www.morphos-team.net/releasenotes/3.2
    "Removed the 2048 pixels limitation where possible
    Fixed the 3D view
    http://www.morphos-team.net/releasenotes/3.6
    "Added optional saving of DPI information for JPEGs"
    http://www.morphos-team.net/releasenotes/3.8
    'version full' command on the version that comes with MorphOS 3.9 prompts "ShowGirls 1.0 (17.06.15)", same as all the versions that came with MorphOS (i.e. since MorphOS 2.0) have always had, confusingly, "1.0" as version string.
  • »12.04.16 - 16:56
    connor
    So it should be just named with the right version to stop confusion and not lead users to download a version that is older in fact just because of its higher version number.
  • »12.04.16 - 17:02
    Exactly. It should be named 1.3 or higher.
  • »12.04.16 - 17:31
    NewSense
    Posts: 1618 from 2012/11/9
    I'd like to have a printing option for this program also.
  • »12.04.16 - 22:17
    Tomo
    Posts: 94 from 2003/7/29
    I'd like to go everytime to the same (chosen) directory with 'save as' . Now 've always to click 3 of 4 times to arrive in the chosen directory. (I leave the original picture on te SSD-card and save al the picures after 'processing' to my hard-disk)
    I assume that 'Raw-handling' is to difficult...
    Regards, Tom
  • »13.04.16 - 08:15
    NewSense
    Don't forget once you have used the history cache for any requester, i.e. where you last saved/accessed the file, you can use the right mouse click and choose a previous directory from a list of about the last 8 choices, I think it is, without having to search back through from a specific volume and its sub-directories to access a recent historically cached directory using just the right mouse click, if that is of any use to you, and pertinent for your above circumstances.
  • »13.04.16 - 16:37
    Posts: 2220 from 2003/2/24
    Hmm.. what exactly do you mean by this? At least when I'm processing my photos, it always goes to the same save-as directory which I've chosen for the first picture. For example if I have 40 photos to process, I save the first processed picture to a certain directory, then select the next picture and process it, and then it automatically gives the previously selected directory for the rest of the pictures when you save-as them. No need to reselect any directories between. Or do you mean it should remember it even when you relaunch the whole program? At least I never want to save the new set to same place, so that hasn't bothered me...
  • »14.04.16 - 03:48
