E-UAE / UAE keyboard shortcuts / questions
    TheMagicM
    Posts: 1220 from 2003/6/17
    What are they?
    I'm running rhLaunch and E-UAE 1.0.0 and I need to be able to exit without having to reboot every time. Need all shortcuts, not just exit.
    Also, has anyone setup more than 1 virtual filesystem? I can setup DH0/Workbench but DH1, a copy of DH0, never mounts.
    How do I get Cybergraphics set up to where I can use 1024x768 inside the emulator?
    [ Edited by TheMagicM 02.02.2016 - 21:35 ]
  • »03.02.16 - 00:40
    amiga4001
    Posts: 454 from 2006/11/16
    Exit is ctrl alt q.
  • »03.02.16 - 04:11
    Posts: 2220 from 2003/2/24
    TheMagicM wrote:
    What are they?
    From docs/keyboard.txt:
    The following key combinations invoke UAE commands or functions:
    F12 + Q Quit UAE
    F12 + R Reset UAE (warm reset)
    F12 + Left Shift + R Reset UAE (cold reset)
    F12 + D Open built-in debugger/monitor
    F12 + S Toggle between windowed display and full-screen mode
    (if supported by the graphics driver).
    F12 + G Toggle mouse-grab mode (in windowed mode)
    F12 + I (or Toggle display inhibit (Amiga screenmodes, not P96)
    Scroll Lock)
    F12 + A Cycle through audio interpolation modes
    (interpolation works with 16-bit audio only)
    F12 + Numpad Plus Increase frame-skip rate
    F12 + Numpad Minus Decrease frame-skip rate
    F12 + F1 Open dialog to insert floppy image in drive 0
    F12 + F2 Open dialog to insert floppy image in drive 1
    F12 + F3 Open dialog to insert floppy image in drive 2
    F12 + F4 Open dialog to insert floppy image in drive 3
    F12 + Left Shift + F1 Eject floppy image in drive 0
    F12 + Left Shift + F2 Eject floppy image in drive 1
    F12 + Left Shift + F3 Eject floppy image in drive 2
    F12 + Left Shift + F4 Eject floppy image in drive 3
    F12 + F5 Open dialog to load emulator state file.
    F12 + Left Shift + F5 Open dialog to save emulator state file.
    F12 + Nampad 0 Quick save emulator state.
    F12 + Right Shift + Numpad 0 Quick load emulator state.
    F12 + Numpad 1 Quick save emulator state to slot 1.
    F12 + Right Shift + Numpad 1 Quick load emulator state from slot 1.
    F12 + Numpad 'n' Quick save emulator state to slot 'n'.
    F12 + Right Shift + Numpad 'n' Quick load emulator state from slot 'n'.
    F12 + F Emulates freeze button of Action Replay cartridge
    (if you have a cartridge ROM loaded).
    On Mac OS X, use F11 rather than F12 in the key sequences above (reason: F12
    is used by Finder on OS X to eject a CD. On OS 10.3, I believe F11 may be
    used by Expose, so you may need to change your Expose settings.) On AmigaOS,
    use CTRL+Left Alt instead of F12 (reason: most Amigas don't have F12 keys).
    Yes, at least like this:
    filesystem=rw,Workbench:Work:Temp/UAE_HD/Workbench
    filesystem=rw,WHD:Work:Temp/UAE_HD/WHD
    filesystem=rw,Storage:Work:Temp/UAE_HD/Storage
    IIRC, I've also tried with image files, but don't have settings at hand now... maybe later. Read the docs/configuration.txt.
    I think CGX isn't possible, but Picasso96 is. I've had it set up once, but can't remember the details now.
  • »03.02.16 - 04:37
    pampers
    Posts: 1071 from 2009/2/26
    I found this quite useful when I was playing with EUAE: EUAE Tutorial
    MorphOS 3.x
  • »03.02.16 - 06:07
    naTmeg
    Posts: 135 from 2004/2/8
    That could be a bug. I'll check that when i'm back on MorphOS. (My peg2 died a month ago)
    Edit: Ops, i didn't see the post of jPV the first time...
    [ Edited by naTmeg 03.02.2016 - 12:19 ]
  • »03.02.16 - 08:23
    Norbi
    Posts: 99 from 2004/6/19
    Only Picasso96 and EUAE-SDL
    [ Edited by Norbi 03.02.2016 - 12:11 ]
  • »03.02.16 - 09:10
    TheMagicM
    Thanks for the replies!
    BTW, any hint as to how to get Picasso 96 working? Also, EUAE-SDL is the only one that can use Picasso 96? Not EUAE 1.0.0?
  • »03.02.16 - 11:43
    Posts: 12565 from 2003/5/22
    Yes.
    > Not EUAE 1.0.0?
    http://fabportnawak.free.fr/uae/E-UAE_1.0.0-JIT.lha contains an SDL version.
  • »03.02.16 - 19:38
    TheMagicM
    Yes.
    > Not EUAE 1.0.0?
    I'm assuming one of the conf files is already working and will boot up into a setup which shows P96 video modes in Screen prefs under WB?
  • »04.02.16 - 11:51
