Kryptos, error on creating image
    asrael22
    Posts: 456 from 2014/6/11
    Hi.
    I'm trying to follow this guide "MorphOS External USB Drive Backup Guide" in MorphOS Library but I got stuck at chapter "Fat32 and Amiga Protection Bits" point 8-9. I'm wiggeling the mouse and click "Create" but Kryptos immediately comes back saying that it can't create an image. A file was actually created but it's empty.
    How can I troubleshoot what exactly goes wrong?
    Or is there another tool that can create disk images? I don't need the encryption feature.
    Manfred
  • »24.01.16 - 18:05
    Posts: 848 from 2007/10/23
    What about copying from RAWDISK:?
  • »25.01.16 - 04:21
    asrael22
    I wasn't aware of RAWDISK:.
    Could work to use it for copy from/to.
    But I don't want to partition my USB stick and so I'd like to create images of my partitions.
    Manfred
  • »25.01.16 - 05:32
    Well, RAMDISK: creates images out of partitions. Take a look:
    xz RAWDISK:Devices/ide.device/0/MAC/partition01
  • »25.01.16 - 06:08
    asrael22
    Can I really compress it there in this location?
    Anyway, I tried copying the partition image to the USB stick like this:
    [code]
    copy DIRECT RAWDISK:Devices/ide.device/0/MAC/partition01 TO Untitled:sys_bak
    [code]
    But the copy is always cancelled after a while and the resulting copy is incomplete.
    Manfred
    [ Edited by asrael22 25.01.2016 - 13:32 ]
  • »25.01.16 - 10:30
    This works for me
    Ram Disk:> time copy DIRECT RAWDISK:Devices/ide.device/0/MAC/partition01 nil:
    Time Elapsed: 39.9822s
  • »25.01.16 - 12:38
    asrael22
    Hmm, yeah. Copying to NIL: works.
    Copying to anywhere real doesn't work.
    At 3.8 Gig it stops. If there a size limit?
    Manfred
  • »25.01.16 - 16:32
    Norbi
    Posts: 99 from 2004/6/19
    I copied the disk image 78 GB.
    All partitions together (one fileimage)
    Target disk(usb) was exFAT
    [ Edited by Norbi 25.01.2016 - 23:00 ]
  • »25.01.16 - 19:59
    asrael22
    Alright.
    Even if this is working I'm not copying the whole partition image if it's only filled 5%. Hmm, can this be piped over xz while copying?
    Anyhow, if there another tool than can create empty images that I can mount and copy over the stuff?
    Manfred
  • »26.01.16 - 16:59
    Norbi
    Its easy :)
    1. FileWrite RAM:image 100000 ; create file image 100000 byte
    2. FileImageCTRL ; put image file to unit 0
    3, Mouter ; choice fileimage.device unit 0, select filesystem and button MOUNT
    4. Format fileimage0
    This is one method for making an image disk
  • »26.01.16 - 17:37
    asrael22
    Thanks.
  • »28.01.16 - 10:03
    asrael22
    Hmm, FileWrite doesn't take a size argument > INT_MAX which is somewhere at 2.1Gig.
    So I've created my own tool that can create large files.
    It's basically just creating an empty file.
    The rest works as you describe.
    Manfred
  • »01.02.16 - 18:05
    Norbi
    Instead of creating the file, you can use any existing n.e. image dvd, avi file or other large file.
  • »01.02.16 - 20:40
