Image editing questions
    emeck
    Posts: 175 from 2014/7/15
    Hello,
    is it possible to convert a color to transparent using Paint/Sketch, ShowGirls or Gribouillis?
    I'm working in a project with Hollywood and Designer, and some of the graphics I'm using are done with GIMP under Linux and later basic stuff like rotating, cropping, resizing, and effects I do mostly with ShowGirls or Designer itself.
    But often I forget in GIMP to save the final image without the background layer, so I would really like to know how to change that under a MorphOS graphic program, instead of going back to GIMP.
    Also, are there any tutorials for editing images under MorphOS?
    Regards
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »11.01.16 - 15:55
    Posts: 847 from 2007/10/23
    ShowGirls has "Insert Alpha..."
  • »11.01.16 - 16:01
    emeck
    Which asks for an image to insert. How does it work? Do I have to create an image of the color I need to convert? And what is the meaning of the other options for "Insert Alpha...", use image alpha channel or brilliance I think? Sorry, my laptop's battery is 0% now so can't check ShowGirls menu at the moment.
  • »11.01.16 - 16:24
    Just do it, all settings are previewed in real-time.
  • »13.01.16 - 17:11
