SimpleMail IMAP
    tolkien
    Posts: 578 from 2013/5/29
    I have tried SimpleMail and I can connect to gmail IMAP server but I have to activate the less secure option in gmail ( https://www.google.com/settings/security/lesssecureapps ).
    It's really dangerous to activate that gmail option?
    Another question. If I delete a mail in SimpleMail I can see the trash icon but never is deleted. What I'm doing wrong?
    Thanks mates!
  • »02.01.16 - 17:42
    diezi7
    Posts: 167 from 2005/7/25
    Hi Tolkien !
    Thanks for your help. Now I can use SimpleMail.
    Google security settings: A good question indeed.
    Did Not try Imap yet.
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »02.01.16 - 18:35
    Derringer
    Posts: 103 from 2008/8/4
    Thanks mates!
    1. It's point of view. From the view ofskynetgoogle, everything you using and not the latest and google based software is not secure.So: yes. From the view of normal user: No
    2. A lot of email client marked only deleted,but not delete the emails of imap box. Maybe simplemail do this. not cheked yet.
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »03.01.16 - 08:14
    emeck
    Posts: 175 from 2014/7/15
    @tolkien
    Trash icon doesn't work for me either, nor the Delete option withthe RMB, but drag and drop mails to the local Deleted folder in SimpleMail does the trick, for both yahoo and gmail imap. I delete them from the local Deleted folder when I want using the RMB.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »03.01.16 - 09:27
    tolkien
    Thanks you all! I'll try your trick emeck!
  • »03.01.16 - 10:20
