Posts: 418 from 2004/2/19
Ok.. it "might" be a hack, even a worse one.
But then, I am a small stupid user, with no idea
of the advantage of simple over smart refresh (or was it the other way
Actually I can`t even notice a real slowdown here
or an instable System (well i have to watch this a time,
but until now nothing strange has happened)
But what i`ve noticed is, that the refreshing Problem
with many Progs has gone. I wish there would have been
a "Propper" solution, but it seems there is none.
So i have to do like i did it on my Amiga, use hacks and patches.
And to be honest, some of them worked really good.
But perhaps someone could find a clean way to solve this
problem? Perhaps it is possible to have smart refresh for those
Progs which demand it?
Until then i will use this patch, because the refresh thing
is realy anoying.
But..as there are so much problems, forget the enthusiasm, and the idea
to add this to the faq section
Anyway I am happy for the now
refreshing Windows in Art Effect (btw, is it just me, or runs Art Effect
a lot more stable since MOS 1.4.2, 1.4 had some serious Problems with AE)
