Animated Boot Screen / Backdrop
    Cool_amigaN
    Posts: 777 from 2011/11/30
    So, does anyone from MorphOS Team feels like adding animated (gif perhaps?)/sound support on the boot screen and animated support on Ambient's backdrop (i.e. some AVI, .MKV whatever playing on the background)? Is it even feasible or will it need external application, much like into OS4?
  • »12.11.15 - 10:16
  • ASiegel
    Posts: 1397 from 2003/2/15
    Quite a few users report that they do not see the MorphOS boot logo at all or only extremely briefly so I do not think it makes a lot of sense to add anything in this area. It should be noted that adding a nice high-resolution animation and sound effects will increase the amount of data that is loaded while MorphOS starts up by quite a bit. In other words, it would slow down the boot process for everyone. Of course, one could make this an optional feature but it just does not seem to be worth the effort given how fast MorphOS boots up.
  • »12.11.15 - 10:39
    Posts: 1521 from 2003/2/24
    You can dump JPEG images to some directory and let Ambient switch to nextbackground every X seconds.
  • »12.11.15 - 15:10
    Yasu
    Posts: 1724 from 2012/3/22
    A flapping butterfly might be nice, even if it's only for a second :-)
    My MorphOS blog
  • »12.11.15 - 16:07
    Cool_amigaN
    @itix
    I know, but that can hardly be called animated backdrop :P
    @Yasu
    My thoughts exactly ;)
    @ASiegel
    Well, how much will the boot process be stalled for displaying an animated gif accompanied with a sound? 500kb/1MB gif + 500kb/1MB a simple sound effect shouldn't cost much. Regarding the boot time, MorphOS indeed starts fast but using the system you get to reboot from time to time due to programs mediating / crashing, so you get to check the boot screen every now and then. Plus even the 3.1 ks had some sort of animation into the rom, let's move it to the OS and get the same feeling :)
    Anyway, it's a cosmetic suggestion, I am sure there are other more urgent matters to cover :)
  • »13.11.15 - 10:25
    Posts: 1099 from 2004/9/23
    When using an SSD MorphOS boots faster than the usual Display can resync. It simply makes no sense.
    Even the current boot screen is quite useless and only visible when it asks for a password.
    OS4 takes ages to cold boot, so they need some visuals to see if something goes wrong.
    If you see a boot screen for more than a second, you probably should defrag or replace your harddrive. :)
  • »13.11.15 - 14:35
    Posts: 847 from 2007/10/23
    @Cool_amigaN
    Kickstart's anim was only shown if no boot volume was found: HD = never. The anim was rather an easter egg. Stupid.
    @Geit
    full ACK
  • »22.11.15 - 13:10
